Author Topic: problem with Tron using MAME 32 edit RESOLVED (sort of)  (Read 2016 times)
weaklink
  • Last login:September 22, 2007, 11:42:28 pm
« on: December 12, 2005, 02:17:39 pm »
I get a flickering double image when trying to play tron, discs of tron, or games with similar resolutions.  Is there a setting that will work on my betson 27" monitor?
« Last Edit: December 15, 2005, 02:42:54 pm by weaklink »
weaklink
Re: problem with Tron using MAME 32
« Reply #1 on: December 12, 2005, 06:22:03 pm »
I should mention that I am using an arcade vga card from ultimarc.  Is everyone else playing tron and discs of tron on their cabs with no problems?
menace
« Reply #2 on: December 13, 2005, 03:42:10 pm »
any chance of a picture?--I would normally say it sounds like the mame32 is outputting 31khz onto a 15khz display but the arcadvga should address that--not to mention the betson 27" should have no problem at that frequency either--truly a mystery.    Sorry i'm not more help but my exposure to mame32 is very limited as is to the betson multisync--
weaklink
« Reply #3 on: December 13, 2005, 04:30:06 pm »
I'll try to get a screen shot.  Thanks very much for the reply.
markrvp
  • NFL Expert
« Reply #4 on: December 13, 2005, 08:02:56 pm »
I've got the exact same setup you do (AVGA, Betson multi 27", Mame32) and Tron works fine.
weaklink
« Reply #5 on: December 14, 2005, 02:11:56 pm »
well I deselected "enforce aspect ratio" and it works fine now, though the image is stretched horizontally.  At least I was able to play a few games last night.  Thanks for the input.
