Author Topic: ArcadeVGA & standard PC monitors  (Read 4094 times)
Bones
  • [Moderator]
« on: November 24, 2005, 02:11:38 am »
I have just had a call from the computer shop who is building my cab PC. I supplied them with my Arcade VGA card for installation at the same time.
The guy claims that with this card installed he is unable to get a display on a standard computer monitor. I kind of expected this but can anyone confirm this is normal?
The main reason I am concerned is because the card had a hard life in transit due to not being packaged properly as per the below pic. I just want as much piece of mind that the card is not faulty and is only behaving the way it is intended.
Thanks guys,
Bones
*Edit- Changed subject description.
« Last Edit: November 24, 2005, 08:51:42 am by BrokenBones »
mccoy178
  • Go Bucks!
Re: Urgent answer on ArcadeVGA & standard PC monitor required.
« Reply #1 on: November 24, 2005, 02:49:30 am »
Tell the computer guy that it has to be attached to the mobo. ;D
danny_galaga
  • Last login:Today at 06:58:09 am
    • dans cocktail lounge
« Reply #2 on: November 24, 2005, 04:04:18 am »
yeah, id go with mccoys suggestion!
Barkuti
  • Last login:July 07, 2006, 03:50:12 pm
« Reply #3 on: November 24, 2005, 07:01:48 am »
By default, an ArcadeVGA only outputs CGA signals (~15.7 KHz Hsync rate), so a computer monitor won't work straight away (30+ KHz Hsync signal required).
The card is designed to be plugged on a SCART TV, an arcade monitor, or some other kind of RGB monitor compatible with CGA resolution 0.7 Vpp video.
The AVGA's "Trisync" patch frees up VGA+ modes so you can use a 30+ KHz non-interlaced display. It is also said that once you have enabled this, if you reinstall the AVGA driver you will be back to your previous state (all modes timed at ~15.7 KHz), but the thing will resort to 31+ KHz Hsync modes for VGA+ if connected to a DDC enabled suitable display (a PC monitor).
With this trick you can still use your CGA display with full safety, and be able to show the windows desktop on a PC monitor.
Cheers
Jess--
  • Last login:April 05, 2023, 09:51:55 am
    • My Botched Cab
« Reply #4 on: November 24, 2005, 07:04:09 am »
He will not get a picture on a standard PC monitor using an arcadevga card.
arcadevga outputs signals at 15khz which is outside the range supported by 99.9% of computer monitors
the simplest way of getting it set up is to drop in a generic video card while installing the operating system / sound cards etc, then once the computer is up and running replace it with the arcadevga and connect it to the arcade monitor.
then all that is left to do is install the drivers for the arcadevga (which can be done easily)
one word of warning..... do not use any other type of ATI card as the generic card while setting it up, if you do you will run into problems installing the drivers for the arcadevga.
EDIT: I am too slow, Barkuti came up with another way around it for you.
Bones
  • [Moderator]
« Reply #5 on: November 24, 2005, 07:07:22 am »
Thanks heaps guys.
This pretty much confirmed what I also thought but I didn't trust myself because panic mode had set in....
danny_galaga
Re: ArcadeVGA & standard PC monitors
« Reply #6 on: November 25, 2005, 04:58:30 am »
does the arcade vga card run regular tvs too? im just wondering what the cheapest way to run a tv with a computer is (obviously one that doesnt have s-video whatits and stuff)
Bones
  • [Moderator]
« Reply #7 on: November 25, 2005, 05:11:52 am »
Damn noobs.
danny_galaga
« Reply #8 on: November 25, 2005, 08:44:21 am »
Damn noobs.
hehe. well, you can see what i can acheive. but do you think i can find out how i should run a tv off a pc?
koolmoecraig
    • My Intervention
« Reply #9 on: November 28, 2005, 12:48:55 am »
Almost 3000 posts Bones and you couldn't figure that out? Jeeesh.
Minwah
    • MAMEWAH
« Reply #10 on: November 28, 2005, 07:37:28 am »
They're all in 'everything else' tho ;)
Bones
  • [Moderator]
« Reply #11 on: November 28, 2005, 08:21:27 am »
You can't see, but I am mooning you two freaks right now with all the aggression I can muster.  8)
And all is cool. Picked up the new PC today and after some initial problems, I got the card to talk to the monitor.
srabelpawz
  • Last login:May 16, 2010, 11:07:44 am
« Reply #12 on: November 29, 2005, 09:48:46 am »
  what did it say to the monitor?j/k stupid pun , i know
  i don't know shite about pc resolutions. my arcadevga only displays in the middle of the screen and is kinda blurry. i tried adjusting the controls on the monitor but it is obviously the res. what resolution is should i run(or what is the average res people run)?
Harry Potter
  • Smite-bait
  • Last login:May 27, 2024, 03:33:28 am
  • Sober until banned. Can post but still can't read.
« Reply #13 on: November 29, 2005, 10:00:20 am »
Have you tried fiddling around with the focus knob?
Now in a tasty new flavour.
srabelpawz
« Reply #14 on: November 29, 2005, 10:01:42 am »
« Last Edit: November 29, 2005, 10:05:30 am by srabelpawz »
Harry Potter
  • Smite-bait
« Reply #15 on: November 29, 2005, 10:06:00 am »
  i don't see a focus buuton on my monitor.
It'll be on the back of the monitor, on the chassis. There will be two knobs, one above the other near the big cord that goes to the picture tube.
Example:
« Last Edit: November 29, 2005, 10:10:29 am by bosss7 »
srabelpawz
« Reply #16 on: November 29, 2005, 10:29:35 am »
  i'll have to check but i don't remeber seeing those ones. i only see the ones on the remote board and the chasis. thanks for the info
