Author Topic: Mini-Pac & 2x Optical Rotary Joysticks  (Read 947 times)
taz-nz
  • Last login:June 12, 2019, 10:12:13 am
  • If all else fails burn the manual!
« on: November 22, 2005, 06:39:38 am »
I'm planning on building a control panel, and just wanted to know if a Mini-Pac would work as the interface for dual HAPP Optical Rotary Joysticks.
I plan to have the following
2x HAPP Optical Rotary Joysticks
1x SlikStiks Tornado Spinner
Six button per player
2x player start buttons
2x coin op buttons
2x function buttons
So I'm going to max out the Mini-Pac with 3x spinners & 26x switches.
Any feed back would be gratefully received
markrvp
  • NFL Expert
Re: Mini-Pac & 2x Optical Rotary Joysticks
« Reply #1 on: November 22, 2005, 08:57:22 am »
The SlikStik tornado has its own built-in USB/PS2 interface, so it won't plug into the Minipac.  The optical rotaries will work with the Minipac fine.
