Author Topic: Sharp Image 33" Question  (Read 2577 times)
Fig
  • Last login:January 25, 2026, 09:13:12 pm
  • (-_-)
« on: November 20, 2005, 07:54:36 pm »
Hi! I got a 33" sharp image monitor that needs a cap kit does anyone know where I can pick one up at?
Its a Sharp Image 33" monitor # KTM-F33
Also does anyone have a manual or a link to DL? Thanks
Ken Layton
  • Guru
  • Technician
Re: Sharp Image 33" Question
« Reply #1 on: November 20, 2005, 08:08:42 pm »
Try the manufacturer at www.sharpimage.net
Fig
  • (-_-)
Re: Sharp Image 33" Question *UPDATE*
« Reply #2 on: November 23, 2005, 05:40:46 pm »
Ok I called Sharp and they said that my tube might be bad.
The tube has a really good picture but I cant get it any brighter then the pic below.
From what  I understand a cap kit well bring the brightness back right?
They want 15.00 for the cap kit and 5.00 for the the manual.
I hope a cap kit will do the trick
Heres the pic
As you can see there is alot of blue in the pic Ive tryed to adjust everthing and this is the best I can get it. Thanks for the help
Ken Layton
  • Guru
  • Technician
« Reply #3 on: November 23, 2005, 06:12:29 pm »
The capkit and manual would be a great starting point.
Fig
  • (-_-)
« Reply #4 on: November 23, 2005, 06:22:09 pm »
I guess that I'm worried that Sharp said the tube is bad I really don't want to spend any money if the cap kit will not work.
Ken does the tube look good to you? The only bad tubes Ive seen they don't show nothing at all.
Thanks for the help
« Last Edit: November 24, 2005, 10:21:03 am by Fig »
Q*Bert_OP
  • Oh yes, we did!
« Reply #5 on: November 23, 2005, 08:35:21 pm »
Have the tube "shot" at a local T.V. repair shop?
Fig
  • (-_-)
« Reply #6 on: November 24, 2005, 10:27:19 am »
qbert247,
I saw in another post you was having the same problem as me monitor not that bright. would the video brightner from happs work on mine?
Could you post a pic of your monitor so I can see what yours looks like to mine?
Thanks for the help
Q*Bert_OP
  • Oh yes, we did!
« Reply #7 on: November 24, 2005, 10:47:24 am »
It might, but try gentally tapping on the neckboard with a screwdriver handle to loosten any debris that by be shorting the heaters.
Fig
  • (-_-)
« Reply #8 on: November 24, 2005, 03:02:42 pm »
Im new to the monitor world so is the neckboard the clear glass looking thing that the adjustments plug into?  ???
Thanks for the help
