Author Topic: help with jamma wiring to vision pro monitor?  (Read 1100 times)
markymarky99
  • Last login:August 20, 2017, 01:53:05 pm
« on: November 20, 2005, 05:25:03 am »
hi, i picked up a 13" vision pro monitor from HAPPS for a cocktail game i'm building.  My JAMMA harness has 4 wires for monitor hookup,,, but the monitor has 7 wires coming out of it for hookup,,,  usually, with most monitors,  I match up RED, GREEN, BLUE, and twist 2 wires together (usually yellow and white) from the monitor and connect them to the one wire that is left from the jamma harness and WALLAH, all is well,,, what do i do with 3 extra wires from the VISION PRO?
Thanks, have a great day!
Jess--
  • Last login:April 05, 2023, 09:51:55 am
    • My Botched Cab
Re: help with jamma wiring to vision pro monitor?
« Reply #1 on: November 20, 2005, 06:34:03 am »
cannot be 100% sure but you will probably find that the wires are as below
Red
Green
Blue
Video Gnd
H sync
V sync
Gnd OR Composite Sync ?
would suggest you get in contact with happs to find out the exact pinout
