Author Topic: anyone know what this 50-60hz dial does?  (Read 2095 times)
arcadepcnut
  • Last login:August 15, 2019, 12:03:07 pm
  • Warhammer 40K, you should try it.
    • BREAKTIME
« on: January 25, 2003, 11:14:30 pm »
I have this dial on my wellsgardner monitor that is right above the horz. hold. It says 50-60hz. Thats all. Turning it yields nothing noticable. ??!!
Ken Layton
  • Guru
  • Technician
Re:anyone know what this 50-60hz dial does?
« Reply #1 on: October 26, 2003, 12:30:16 pm »
It interacts with the vertical size control and gives you a little bit more compression/expansion. Think of it as a very fine adjustment.
Edgedamage
  • Last login:October 06, 2018, 12:21:23 am
« Reply #2 on: October 26, 2003, 08:53:36 pm »
That dial saved my arcade vga from getting tossed in the trash.
Curls in the squat rack !?!?!
Ken Layton
  • Guru
  • Technician
« Reply #3 on: October 27, 2003, 12:31:32 am »
It's smaller than all the other controls on the monitor so it's very easy to overlook it.
jerryjanis
  • Last login:February 02, 2023, 01:56:44 am
  • Skate or Die!!!
    • Jake's Joystick
« Reply #4 on: October 27, 2003, 11:25:00 am »
On my Wells Gardner k7191, certain resolutions were appearing really messed up.  I've read a few people who have had the same problem.  The image for Ms. PacMan, for one example, would "curl" at the bottom of the screen, making the game very ugly.  (If you've seen it then you will know what I'm talking about).  Adjusting the 50-60 Hz knob fixed the problem.
