Author Topic: Painting the control panel  (Read 1681 times)
Craig Pilecky
  • Last login:April 15, 2003, 02:47:32 am
« on: January 25, 2003, 09:33:09 pm »
I drilled the holes for my control panel, and sanded it down nice. I just need to paint it, and then im going to mount the joysticks and buttons.
Im not sure what type of paint to use. Should I use spray paint, or brush? Does it need undercoating, or just  2 or 3 layers of black?
Hellfromabove
  • Last login:January 08, 2020, 05:45:41 pm
  • Soundwave Superior, Constructocons Inferior!
Re:Painting the control panel
« Reply #1 on: January 25, 2003, 10:38:45 pm »
I asked my mom's friend what I should do and he said that I should just go with brush paint cause it's cheaper and spray paint is just too expensive for a can, I have used spray paint on a CP I was making and it just runs and stuff like that. Also if you put primer on first, which I highly suggest, you will only need one coat. Also the primer prevents the paint from seaping in to the wood and making to wood show. Thanx.
-See Ya!!!
spidermonkey
  • Bombjack junkie
« Reply #2 on: January 25, 2003, 10:43:21 pm »
You can use spraypaint but I would make sure that its epoxy paint and if you're not going to cover the surface with acrylic or polycarbonate (you really should I might add) then I would spray on a good 4 or 5 coats of clearcoat on top of the black. Wear through will eventually occur just from normal abuse but the clearcoat will slow down the process somewhat.
Best of luck :)
S.M.
"Sinistar has bad breath"
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
« Reply #3 on: January 26, 2003, 01:04:18 am »
using mdf?  priming first is a good idea
Frostillicus
  • Arcade Artist
  • Last login:April 18, 2023, 07:36:29 am
    • My MAME cabinet site
« Reply #4 on: January 26, 2003, 02:25:47 pm »
If you're using wood make sure you use a few coats of sanding sealer or the grain will show through.
Rocky
« Reply #5 on: January 27, 2003, 12:04:19 pm »
I would use rollers instead of brushes. It makes a much nicer finish.  Also, sand between coats with fine grit.
Good luck,
Rocky
