Author Topic: 2 psx controllers .. do they share same ground or different ones?  (Read 3204 times)
Negativecreep0
  • Last login:November 28, 2020, 10:59:49 am
can two psx controllers share the same ground going into a db25 plug or do i have to split them up???
thanks
TalkingOctopus
  • Last login:August 04, 2025, 03:48:02 am
    • My Arcade
Re: 2 psx controllers .. do they share same ground or different ones?
« Reply #1 on: November 17, 2005, 01:53:39 pm »
you need to split them up.
Negativecreep0
« Reply #2 on: November 17, 2005, 02:01:39 pm »
so if each controller is going to a p360 i assume they need seperate +5 connections too?
damn to many connections to fit 2 psx in one db25 cable, 6 buttons + start + 4 directions + ground + +5v = 13 connections for each control = 26 points for 2 controls.......
damn
dennis808
  • Last login:May 13, 2021, 08:40:00 am
  • Holy Sanwa-sticks!
« Reply #3 on: November 17, 2005, 04:33:27 pm »
26 is perfect if you use the (unshielded) groundcable in a db25 cable, I did it with my PS2 hack...
"Complexity is the process by which the obvious is obscured by the irrelevant." -HSW
Negativecreep0
« Reply #4 on: November 17, 2005, 05:59:16 pm »
can you elaborate on that where is this 26th cable? and did you use 2 psx controls to one db25 cable???
Negativecreep0
« Reply #5 on: November 17, 2005, 07:05:31 pm »
since both player one controls and player two controls on the arcade stick are all connected with daisy chains for its ground then won't ps1 controller and ps2 controller grounds come in contact anyway????
dennis808
« Reply #6 on: November 18, 2005, 09:02:12 am »
I used a separate ground for each pad.
Up, Down, Left, Right, Triangle, Square, Circle, Cross, L1, L2, start & ground = 13 functions/ wires
Most db25 (printer-extention) cables have 25 shielded and color-coded wires PLUS 1 bare ground-wire going from plug to plug, meaning you have (25 + 1 =) 26 cables to use.
« Last Edit: November 18, 2005, 09:04:34 am by dennis808 »
