Author Topic: [problem] joysticks only moving right in neo mvs problem  (Read 1951 times)
iwillfearnoevil
  • Last login:February 13, 2010, 07:08:43 pm
« on: November 16, 2005, 10:36:20 pm »
I'm sure I'm doing something wrong on a new pair of joysticks. i tried to install them into my neo geo mvs cabinet to test them out but seem to have run into a problem. the joysticks only register up right, right, and down right in the neo test screen. can't get anything to register on the other 5 directions. i've done lots of searches here but couldn't really find anthing except people talking about installing them with no problems. when installing there were 5 wires -
« Last Edit: November 23, 2005, 09:53:25 am by jened »
iwillfearnoevil
Re: [problem] translucent joysticks only moving right in neo mvs problem
« Reply #1 on: November 18, 2005, 02:04:10 pm »
sorry to bump so soon (less than 48 hours) but i'm really hoping to work on my new control panel this weekend. any ideas anyone? pretty please?
MameJunkie
  • Last login:March 19, 2009, 08:23:45 pm
  • Eeeeeeeevil
« Reply #2 on: November 18, 2005, 02:38:01 pm »
Looks like the "Left" isn't hook up correctly.
Is there a short?
Check the encoder?
Teamwork - A group of people running around doing what I say.
iwillfearnoevil
« Reply #3 on: November 18, 2005, 02:49:03 pm »
thanks so much for the reply. could "left" not working prevent up/down from registering by itself? how do i check for a short - with a multimeter? what's weird is it's both joysticks doing this. i've put another set of joysticks that was working although crappily back in, in the meantime so i think the harness is okay. it's still got a 2 slot neo pcb inside so no encoder. thanks for the post.
Jess--
  • Last login:April 05, 2023, 09:51:55 am
    • My Botched Cab
« Reply #4 on: November 18, 2005, 03:02:17 pm »
sounds like you have the sticks wired wrong, Gnd only going to right switch instead of all switches
double check your ground lead from your harness goes to all 4 switches on the stick
(the reason you get up-right and down-right is that when you push the joystick right you give the rest of the switches a rout to gnd)
iwillfearnoevil
« Reply #5 on: November 18, 2005, 03:21:33 pm »
there's 1 input for ground and inside it goes to all 4 switches - not sure if i can take it apart, but maybe i just connected ground to right. thanks so much for the post, i'll try to rewrite tonite.
edit: thanks for your help everyone, my harness was wired differently than i thought.
« Last Edit: November 30, 2005, 10:25:16 am by jened »
Jess--
    • My Botched Cab
« Reply #6 on: November 20, 2005, 07:37:26 am »
thats what I meant.. you have your right and ground reversed on your wiring loom
