Author Topic: WTB: PCB mounting feet  (Read 1805 times)
rotinapple
  • Last login:November 15, 2005, 12:51:56 pm
« on: November 13, 2005, 01:00:39 pm »
Does anyone have a set of PCB mounting feet, for the optipac?  I forgot to include them in my last order.  send me an email at:  rotinapple@yahoo.com
Thank you
Jabba
  • D-Hutt
  • Last login:November 16, 2020, 02:17:20 pm
  • I find your lack of faith...disturbing...
Re: WTB: PCB mounting feet
« Reply #1 on: November 13, 2005, 02:13:45 pm »
Just an idea...Some people here use pieces of a cut up Bic pen to secure the PCB. Some others claim a straw from McDonalds cut up works too. Search for mounting feet here for more info...
Vids:  Home built MAME machine, Crystal Castles. Arkanoid
Pins:   Williams Aztec (working). Stern Nugent (not working...yet), Williams Phoenix (major not working, missing parts.... )
Always on the lookout for buying 90's game with Ramps that need work...
Q*Bert_OP
  • Oh yes, we did!
« Reply #2 on: November 13, 2005, 02:46:54 pm »
I'll second the "drinking straw" mounting
Scott84
  • Last login:May 17, 2022, 08:24:59 pm
« Reply #3 on: November 13, 2005, 07:44:18 pm »
ANyone got pics of mounting it this way?
"Computer games don't affect kids, I mean if Pac Man
affected us as kids, we'd all be running around in
darkened rooms, munching pills and listening to
repetitive music." -- Marcus Brigstocke
pmc
  • Last login:February 07, 2026, 12:21:50 pm
    • website
« Reply #4 on: November 13, 2005, 08:37:44 pm »
Yeah. I was thinking the same thing. Sounds like it wouldn't be strong enough. And also, they'd be striped wouldn't they?  ;)
If it doesn't look goofy, and it's strong, I'd try it.
-pmc
Mark70
  • Last login:August 19, 2011, 11:22:49 pm
« Reply #5 on: November 13, 2005, 08:59:43 pm »
You can use scrap plastic anything to mount them.
I'm not sure about the straw idea or bic pen idea, since the idea of the mounting feet is prevent any metal in contact with the board from grounding out to whatever you've fastened to.... if I understand it correctly.
I used plastic plugs for the ends of the metal tube frames in my ikea desk.  I put a screw through the hole in the board, into the plastic, then screwed the piece of plastic to the plywood (in my prototype CP) so that the scew in contact with the circuit board only touches plastic.
Am I correct in that  you screw the circuit board to the tube part of the mounting feet with one screw and then mount the foot with a separate screw in the offset foot part?  thereby a similar situation where the screw through the circuit board isn't touching anything but plastic?
... arcade builders could someday rule the world...currency would be reduced to quarters only, and wars would be settled
