Author Topic: Speaker wiring help please  (Read 2184 times)
spystyle
  • Thanks alot, now I have to build a time machine and warn myself yesterday!
  • Last login:February 23, 2021, 02:30:18 pm
« on: November 12, 2005, 11:59:38 pm »
Hello from Maine.
I have 3 speakers on a cab. One is large and in the center and the other two are small are spread out.
I intend to use the large speaker for 80% of the volume and have the small speakers play at 20% simply to create "stereo imaging"
The amp I have is two channel, no balance knob.
I'd like the center channel to be "single channel stereo" and the two small speakers to be L and R.
How would I wire this? Do I connect L+ and R- to the center channel to create "single channel stereo" and run an additional pot to the little speakers to turn them down to 20% of the main volume control pot?
Is there something like a pot that I can wire to control balance?
Thank you!
Craig
« Last Edit: November 13, 2005, 12:01:47 am by spystyle »
headkaze
  • 0x2b|~0x2b?
Re: Speaker wiring help please
« Reply #1 on: November 13, 2005, 06:27:43 am »
I would guess you use the following setup
(-)_(+)_(-)_(+)
spystyle
« Reply #2 on: November 13, 2005, 10:27:09 am »
Well I called Radio Shack and the highly trained teenagers over there claimed there is nothing like a potentiometer that handles balance. So I looked all about and found this:
(from http://www.bcae1.com/)
I suppose I will wire it like that and add a second volume control to the small speakers to keep them at 20%
« Last Edit: November 13, 2005, 11:14:10 am by spystyle »
