Author Topic: Latex HVLP on the cheap  (Read 2890 times)
stratjakt
  • Last login:October 16, 2006, 11:43:58 am
« on: November 11, 2005, 12:18:58 am »
So I went out and picked up a Wagner FineSpray HVLP kit from Lowe's on the weekend, 98 bucks, after reading some good reviews.  It's no 1000 dollar uber-gear, but it seems to be a good DIY-er/hobbyist tool.
I have a couple cabs to get ready by xmas - an Xmen vs Street Fighter and a Puzzle Bobble 3 (both conversions from ho-hum games).  It's too cold now to spray oil, or anything harsh - I need to work in an unfinished room in the house..
So, I needed to spray latex.  Cue all the comments about how you can't spray latex with this kit.  The guy at Lowe's got mad when I tried to get him to mix some paint!  He was pointing at the Wagner box, and actually said "You aren't allowed to spray latex with that!"  - like the Wagner squad was going to come put me in jail..
Anyhow, after some playing around, I found a way..  That way is alcohol (the solution to, and cause of, all life's problems).
I first poured out a pint of the paint (eventually got Behr Interior Satin Latex Enamel from HD since I got sick of the Lowe's guy), then thinned it with - cant remember the name.  Not Floetrol, the stuff I bought at Lowe's, it's Wagner branded latex paint conditioner, and it's thinner than floetrol..  I thinned it to the mfg's directions with it, 4 oz to the quart (or 2 oz to my pint.. I'm metric.. And eyeballed it).
Anyways, still very thick, glopped out of the gun like crap..
From there I tried thinning it further with water.  Glopped out like crap, and ran and dripped.. Blech..
So I tried again, after reading on a hobbyist site about using a mix of water and alcohol.  I one-upped him, and used straight Isopropyl from Rite-Aid, 91%..  I added it till it got thin, like spraypaint thin - which really wasnt much, it thins latex fast - a little goes a long way..
So the formula was probably something like 4:1 paint to alcohol..
Strain it, spray it..  It's magic science..  The alcohol makes the paint thin in the gun, which is good.  The heat from the turbine, and just the volume of air involved, evaporates a good deal of it, before it even hits the work piece.  No drips, no sags.  I just layed down my second coat, and it looks awesome.
Some notes, from my limited experience - work fast, dont let it evaporate in the can, that stuffs thickening while you stand around scratching your rear..  That's not to say rush it, but dont take a smoke break or run errands..
It does leave a slight texture, quite fine orange peel.  For an arcade, it looks great, its very much like the texture a vinyl covered cab would have.  You cant feel it with your fingers..
Also, clean the gun immediately - as soon as I'm done I spray a bunch of warm soapy water through it, then dismantle, clean the bits up really good.  It's hella-easy to dismantle and clean.
You could wear a respirator if you wanted, but it's just latex.  It doesn't stink up the joint any more than rolling up a wall.  There's a regular dustmask suitable for being around sprayed latex, that's what I'm using.  A little atomized alcohol wont hurt me too much.
The paint gets so thin I'm pretty sure this method would work with the 60 dollar handheld wagner hvlp deal at home depot (the one on sale this month for 40 bucks).
I figured this information would be useful to you folks, since it's news you can use.   It's a great way to paint a cab.
I really like this rig, and next summer I'm going to see what it can do spraying the stuff it's meant to (oils) on another project cab waiting in the wings.  To me, 100 bucks is worth not going through the hassle of trying to roll on a finish.  I cussed like a sailor for two weeks trying to get my PC10 a nice satin black, without any rollermarks.  I've spent about two hours getting to the same point on this cab (1.5 of that either cleaning the gun or mixing paint).
It's a great way to get a good paint job on a cab for cheap.
I'm also singing the praises of BIN primer over the laminate on the cab - that stuff means business.  Sticks to everything, and dries fast.  I was sanding the first coat after an hour.  Don't spray it though, consider whatever you use to apply it garbage.  It does come in spray cans, which I used for the nooks and crannies on the front of the cab.
J-Rod
  • Last login:February 10, 2008, 06:17:07 pm
  • Gaming junkie
Re: Latex HVLP on the cheap
« Reply #1 on: November 11, 2005, 07:58:40 am »
More power to you man, that's the spirit of DIY. I'll have to remember that when I retrofit this Aerofighters cab that was donated to me. I don't yet have any gear to do spraypainting with, and your method sounds like it'll give a great result. Any digipics? Maybe one with some reflection so the texture can be seen, as well as the evenness of the coat?
Timoe
  • Team-Oh-tAy-Oh
    • Rattlin' Trash
« Reply #2 on: November 11, 2005, 09:04:36 am »
Just a question:  Why not use oil based paint?
stratjakt
« Reply #3 on: November 11, 2005, 04:52:09 pm »
I didn't use oil because it's too cold to paint outside, and that stuff is just obnoxious.
From what I gather, latex acrylics and other water-bourne finishes have pretty much surpassed oils and solvent based paints, and the old wisdom of only oil being durable enough is obsolete.  Car's are sprayed with water-based acrylics at the factory these days.
The treat was finding I could apply it well with a cheap HVLP get-up, which is supposedly difficult or impossible.  I've had experience with airless pumps (PowerPainter et al), and I wouldnt use one of those pieces of junk to paint my worst enemies outhouse.
After drying overnight, the texture smoothed itself out quite a bit, it's even less noticable.  I could sand and recoat a few times and probably get a nice smooth finish, but the slight texture looks more natural to me, so I might leave it.
Latex acrlyics are just better, IMO.  They dont stink up the joint or pose any real health risks, cleanup is a breeze, and a much wider variety of finishes and colors is available.  It's tough to get oil in anything but semi-gloss or gloss, for instance.
That said, I think I'll repaint my Donkey Kong next summer with oils, and see how it can come out.  They have a smooth semi-glossy finish in the wild.
I'll get some photos after a couple more coats.  I think I'm going to try to stencil the Capcom logo onto the cab, the gun gives me plenty of control for such a task, need to phone around to see if I can find somewhere to cut the stencils out for me.
tivogre
  • Last login:July 18, 2013, 09:13:34 pm
    • ogredog.com
« Reply #4 on: November 11, 2005, 05:00:14 pm »
Make sure you're wearing a solvent rated mask.  Work in a well ventilated room... and take those smoke breaks... or any FIRE far away.
I guess I'm saying be careful with the vaporized alcohol.
 :police:
Tailgunner
« Reply #5 on: November 13, 2005, 01:47:52 pm »
johnvv
  • Last login:June 19, 2012, 08:36:20 pm
« Reply #6 on: November 14, 2005, 12:29:47 am »
I'll agree on the original topic that the Wagner FineSpray HVLP unit is a good budget choice for a sprayer.  With proper preparation time, testing, and application, I was able to do a very nice job on a Joust restore.  You just need to practice with it first.  Sure, a real HVLP rig would be nice, but Wagner FineSpray HVLP works for small jobs.  If I was painting several cabs a month, I would use a real rig.
I also had problem thinning some the paint.  Here in California, you can't buy true oil-based paints due to the environmental laws.  I'm no expert, but the legal paints are latex or some hybrid oil-base.  These paints did not thin well with paint thinner, in my experience.
