Author Topic: Odd mouse question  (Read 1737 times)
menace
Odd mouse question
« on: January 23, 2003, 09:41:42 am »
As I have been told and have discovered, the faster you move the mouse (spinner) the further it goes do to some programmer's quirky sense of world order.  My question, is there a way to equalize (for lack of a better word) the mouse so that it travels the same distance regardless of the spin rate?  Thanks!
Nyrine
  • Last login:August 19, 2003, 02:43:06 pm
Re:Odd mouse question
« Reply #1 on: January 23, 2003, 10:13:35 am »
Under Windows 2000 (and others I guess)
Control Panel -> Mouse -> Motion
Set Acceleration to None.
eightbit
  • Last login:September 07, 2019, 07:38:11 pm
  • My cab is never done...
« Reply #2 on: January 23, 2003, 01:16:48 pm »
You can also adjust the speed and sensitivity from within mame with the in game menu (mapped to tab by default).
My statements are my own opinions. They have the value that the reader gives them. My opinion of my opinion varies between foolish and brilliant and these opinions often change with new information.
menace
« Reply #3 on: January 24, 2003, 11:27:42 am »
I have been fiddling with these for some time but haven't discovered how to reduce the speed vs. distance thing common in ps/2 mice--I am using advmame in a 98SE DOS OS--Any suggestions as to what settings minimize these effects? Thx
ErikRuud
« Reply #4 on: January 24, 2003, 11:48:00 am »
You have to adjust your mouse settings in windows.  For most versions of Windows,  I beleive it is under "Settings", "Control Panel", "Mouse".  The tabs on the mouse setting will depend on which mouse you have.
American Laser Games Wrapper
O2em Rom Utility
rampy
  • *shrug*
  • Last login:March 02, 2007, 11:32:16 am
  • ...as useless as a JPG is to Helen Keller
    • Build Your Own PVR
« Reply #5 on: January 24, 2003, 12:03:19 pm »
you'd shut off mouse accelration in your DOS mouse driver...
The effect your describing comes from mouse accelleration done on a driver level...
find where your DOS mouse driver is (assuming you are  in "real" dos not dos window in windows98se)  probably called mouse.com or the like... and do a
mouse.com ?
or mouse.com /?
or mouse.com -?
or mouse.com help
  command (replace mouse.com with the name of your actual mouse driver loaded in your autoexec.bat) and hopefully it will pull up a list of commands and switches you can set to adjust sensitivity and hopefully shut off acceleration.
If you find a setting you like you'll want to add it to your autoexec.bat so that it boots up that way every time.
Some people have futzed with the spokes on the actual encoder wheel to get different types of response for certain games, but i don't believe that to be symptomatic of the issue you described...
good luck!
rmapy
