Author Topic: Monitor almost dead, recommendation for 20" PC monitor  (Read 1470 times)
telengard
  • Last login:October 21, 2025, 02:12:46 pm
  • Yeah, it's a classic! 21+ on BYOAC and still goin
    • S T U R C A D E
« on: November 05, 2005, 07:19:56 pm »
Does such an animal even exist?  I have a 19" one now and it is about an inch less than a std 19" arcade monitor.  I have debated (way too much waffling) getting a WG3100 but the consencus seems to be that the vector games (including backdrops) don't look so hot.
Any recommendations?  I'd like to not get a flat screen one if possible, and cabinet friendly would be a plus too since I have a rotating monitor and would have to probably rip off the case.
~telengard
S T U R C A D E     M.A.M.E. Cabinet
http://www.briansturk.com/mame.html
grueinthebox
  • Last login:February 07, 2014, 12:37:03 pm
  • Feed your head.
    • red42.com
Re: Monitor almost dead, recommendation for 20" PC monitor
« Reply #1 on: November 06, 2005, 04:41:26 pm »
Hop on eBay, do a search for "20" monitor" within driving distance of your location.  Save the search as a favorite and keep checking back until one comes up really cheap and doesn't get any other bids.  I picked up a couple of 20" IBM monitors for Sun workstations for $20 each this way, then got the adapter cables to use them with PC for $3.
The IBM P200s I got are reasonably "cabinet friendly"...  Removal of the plastic casing leaves you with the tube and guts surrounded by metal shielding, with the controls on a very simple remote board.  All easily mounted using a piece of plywood.  Also has a nice mechanical on/off switch that allows the thing to be easily left on without worrying about standby mode or power loss.
EDIT: fixed typo.  I know how to spell "doesn't".  :P
« Last Edit: November 08, 2005, 09:23:52 pm by grueinthebox »
"All right. It's Saturday night. I've got no date, a two liter bottle of Shasta, and my all Rush mix tape. Let's rock!"
telengard
    • S T U R C A D E
« Reply #2 on: November 08, 2005, 12:28:44 am »
Hop on eBay, do a search for "20" monitor" within driving distance of your location.  Save the search as a favorite and keep checking back until one comes up really cheap and donesn't get any other bids.  I picked up a couple of 20" IBM monitors for Sun workstations for $20 each this way, then got the adapter cables to use them with PC for $3.
Thanks for the idea, I did just that (made a search on eBay).  I wish there was an arcade monitor that could fufill my needs but it seems there still isn't on out yet.  I had a lot of hope for the neotec one...
~telengard
