Author Topic: PC to Electrohome G07 CB0  (Read 1107 times)
eccs19
  • Last login:April 20, 2021, 10:36:08 am
  • Just plugin away!
« on: November 03, 2005, 01:35:31 pm »
OK, as I'm sure most of you are now aware, I'm working on a machine for my own use.  My eventual plan is to have it running mame.  I'm going to be running a P3 - 500 (approx), and want to use and arcadeVGA card in it.  The cab is NOT wired to the JAMMA standard.  I'm not afraid to do any rewiring, but I'm not sure if I should just use a VGA breakout cable, or a Arcade monitor video amp (or if it's even needed with this monitor), or if I should just get the J-pac and wiring harness, and do it that way.  I realize if I don't use the J-Pac I will need an I-Pac.  I also know the I-Pac with arcadeVGA is probably the cheapest, but I'm just not sure what hookup will work this this monitor. (and how easy it would be to do)
Thanks again!
Working - Mr. Do! - Neo Geo 4 Slot - Bartop Mame
Project(s) - Pacman
