Author Topic: Monitor discharge  (Read 2812 times)
eccs19
  • Last login:April 20, 2021, 10:36:08 am
  • Just plugin away!
Monitor discharge
« on: November 01, 2005, 08:59:00 pm »
I've unhooked my monitor to install a cap kit.  My problem is that I went to discharge the monitor, and didn't get the ZAP that everyone mentions.  The monitor was last running less than a week ago. Am I doing something wrong, or is it possible that in less than a week the charge has dissipated?
Working - Mr. Do! - Neo Geo 4 Slot - Bartop Mame
Project(s) - Pacman
menace
Re: Monitor discharge
« Reply #1 on: November 01, 2005, 09:14:32 pm »
yup very possible--just try it again for good measure and then you should be good to go.
eccs19
  • Just plugin away!
« Reply #2 on: November 01, 2005, 09:32:49 pm »
Would that be because some of the caps are toast, and the voltage is leaking out there, or is it just nature of the beast, and one never knows what one's gonna get?
Project(s) - Pacman
Nipedley
  • Last login:October 04, 2024, 12:03:26 am
« Reply #3 on: November 02, 2005, 01:15:22 am »
it doesn't mean anything, that's just the way it is! I got no zap either, no spark, no noise, nothing. Not sure why, but I don't mind. =)
MaximRecoil
« Reply #4 on: November 02, 2005, 02:44:04 am »
I haven't gotten a zap or crack noise or anything yet, and I have been fiddling with that damnable arcing lower Punch-Out monitor for about a week now. Most monitors self discharge when you turn them off anyway, unless they are busted in some way that prevents them from doing so.
eccs19
  • Just plugin away!
« Reply #5 on: November 02, 2005, 08:09:54 am »
All this information from you guy's is great.  I was worried I would kill myself.  Now when I go home from work, I can dis-assemble.
Thanks again everyone.
Project(s) - Pacman
SirPeale
  • Green Mountain Man
  • Trade Count: (+23)
« Reply #6 on: November 02, 2005, 08:24:10 am »
Heck, I rarely bother discharging anymore.  Unless I've *just* had the monitor on.  If it's been off for more than 15 minutes, I just squeeze and pop it off.
Jess--
  • Last login:April 05, 2023, 09:51:55 am
    • My Botched Cab
« Reply #7 on: November 02, 2005, 08:25:10 am »
would say discharge before you reassemble, have had a few belts from discharged tubes that have picked up a charge while not connected, dont ask me how they do it.... they just do
eccs19
  • Just plugin away!
« Reply #8 on: November 02, 2005, 01:55:49 pm »
I bet that would wake you up in a BIG hurry!
Project(s) - Pacman
thebrownshow
  • Last login:December 14, 2010, 03:14:32 pm
« Reply #9 on: November 02, 2005, 06:55:20 pm »
Here's a question, since I'm about to do this myself:
Will my monitor discharge itself if it's left unplugged?
SirPeale
« Reply #10 on: November 02, 2005, 07:22:06 pm »
See my post above.  Won't completely discharge, but if it's working the way it should, it will.
Easy way to do that (what I do, anyway) is pinch the cup back so the anode is exposed, and (making sure you're not contacting the anode in any way) touch it to the hole.  It may or may not spark.  Either way, it'll do what it's supposed to.
thebrownshow
« Reply #11 on: November 03, 2005, 10:48:29 am »
I guess my question was more along the lines of "does it need to be plugged in to discharge the way it should, or should it be UNPLUGGED in order to discharge the way it should?"  Does the monitor need to be connected to EARTH GROUND in order to naturally discharge?  Like most people, I'm nervous as hell about zapping myself the first time I do this.
Jess--
    • My Botched Cab
« Reply #12 on: November 03, 2005, 03:18:46 pm »
the charge in the tube only relates to the outside of the tube thats what you short out when you discharge a tube, so it will make no difference if the monitor is plugged in mains or not.
eccs19
  • Just plugin away!
« Reply #13 on: November 03, 2005, 03:22:57 pm »
See my post above.
Project(s) - Pacman
subcriminal
  • Last login:November 20, 2019, 12:58:00 pm
« Reply #14 on: November 03, 2005, 04:12:14 pm »
Mine was like that too. I got a long piece of wood, had a nail in one end and earthed it to the chassis, poked  around under the cup and nothing... makes you wonder if you did it right :laugh:
Jess--
    • My Botched Cab
« Reply #15 on: November 03, 2005, 04:34:31 pm »
My bits for discharging are really simple.... 1 slim screwdriver and 1 bit of wire with a croc clip on each end (one end for the scredriver and one end to clip on the braid across the back of the tube)
very rarely hear / see anything when discharging while taking apart, but quite often see / hear a small spark when discharging before putting back together (about the same size as a spark from a spark plug in a car)
thebrownshow
« Reply #16 on: November 03, 2005, 05:24:00 pm »
thebrownshow
« Reply #17 on: November 03, 2005, 08:54:44 pm »
Ok, I just did it...not a spark, nothing.  Removed the board, no problems at all.
I had the monitor off and unplugged for four days.
