Author Topic: Connecting a PSone LCD screen to a PC  (Read 3577 times)
markb
  • Last login:April 30, 2011, 06:41:02 am
  • The One and Only.
« on: October 30, 2005, 07:46:06 am »
I've bought a PSone LCD screen so I can connect it up to a portable arcade machine however I am having some trouble determining the required connections. I've been searching the boards and googling for the last 2 hours with no luck.
The PSone has a 12 pin connector of which only 9 are used on the LCD as follows:-
    PSone         LCD
1 Ground         Yes
2 Right Audio   Yes
3 Ground         Yes
4 Left Audio     Yes
5 S Video Y      Yes
6 Pal TV           No
7 S Video C      No
8 Video GND    Yes
9 Blue              Yes
10 +5V            No
11 Red            Yes
12 Green         Yes
Firstly is it possible to connect this to a PC using a composite out cable?
Secondly, what are the connections I would need to make?
I'm just starting to learn about this so any help would be appreciated.
Jess--
  • Last login:April 05, 2023, 09:51:55 am
    • My Botched Cab
Re: Connecting a PSone LCD screen to a PC
« Reply #1 on: October 30, 2005, 08:30:58 am »
you can connect composite video to a PSone screen, it goes in on the 3.5mm connector by the headphone socket, its an unusual connector with 4 connections instead of 3 (I always wire a phono socket to the board internally).
you can also mod these screens to work with VGA although a lot of people struggle to get the timings right. More details here http://starfox.ucc.asn.au/carcomp/serio_lcd.htm
markb
  • The One and Only.
« Reply #2 on: October 30, 2005, 08:36:53 am »
Unfortunately it's not a Sony brand LCD so it does not have a composite input. Also for the VGA hack I believe it requires a +5V connection so that the PC can turn it on, and it doesn't have one of those either. It may still work as a VGA but I TV out would be preferable.
Jess--
    • My Botched Cab
« Reply #3 on: October 30, 2005, 08:57:06 am »
what type of psone screen is it, most do have composit input somewhere.
markb
  • The One and Only.
« Reply #4 on: October 30, 2005, 09:12:53 am »
Bigben Interactive make the screen, and I cannot find any information on it at all. The only input socket it has looks to be for headphones.
I have worked out though it gets its picture from the Psone using
S-Video Y
Red
Green
Blue
No idea how to get this signal from a PC yet.
markb
  • The One and Only.
« Reply #5 on: November 05, 2005, 06:56:58 am »
The power supply arrived today and the screen boots up no problem on  my old PS1, still no joy connecting it to a pc yet.
I've tried various combinations of wires and worked out that it requires and RGBY (or yRGB) signal to work the Y being the Luminance. I'm still hunting around to try and find out if this is possible to get from either a VGA output or TV-output.
In the meantime does anyone know if this is even possible?
markb
  • The One and Only.
« Reply #6 on: November 06, 2005, 05:14:48 am »
I'm posting this just in case anyone else tries this at a later date and the link is useful as well so forgive me for continuing the thread.
I finally got it working this morning after finding this useful article:-
http://lagnarok.no-ip.com/index.html
I hooked it up using the following:-
VGA        LCD Input
Red           Red
Green       Green
Blue          Blue
Ground     Ground
H Sync      S-Video Y
V Sync      S-Video Y
Using powerstrip on an old Matrox G100a I had lying around I was able after a lot of tweaking to get a reasonable picture by using the Arcade setting. Also I used Real VNC so I could play with the settings and not change over the vga plug constantly.
I would recommend though buying an official Sony screen as the resoluton on the one I have is not very good at all.
StephenH
  • Last login:January 09, 2023, 06:15:45 am
« Reply #7 on: November 06, 2005, 05:41:43 pm »
Most PCs have a +5V output.  In fact, the easiest place to get access to it, is an unused disk drive connector.
Also, there are some external transformers that supply 5V too.
