Author Topic: Front end with LARGE fonts?  (Read 1955 times)
DemonBrew
  • Last login:December 10, 2014, 06:05:50 am
« on: October 23, 2005, 03:54:27 pm »
I'm looking for a MAME front end that I can display larger fonts for the games list. My TV is somewhat blurry. It's very hard to read the game list. Suggestions?
Background info:
Project info here.
Blurry TV forum post here.
Mamewah slow to load some games topic here.
this space intentionally left blank
markrvp
  • NFL Expert
Re: Front end with LARGE fonts?
« Reply #1 on: October 23, 2005, 04:39:20 pm »
It's been awhile since I worked with MameWah, but I thought font and size were two things you could specify in the Mamewah .ini file.
youki
  • Atomic Front End Creator
    • Atomic Front End
« Reply #2 on: October 23, 2005, 05:02:43 pm »
I think you can define large font with almost all Front Ends.
You can do that with my Front-End AtomicFe , but i think with others too.
mccoy178
  • Go Bucks!
« Reply #3 on: October 23, 2005, 05:11:49 pm »
You may want to check out MALA as it is very user friendly, but I believe Mamewah has the most support out there(I'm not knocking you other guys ;)), www.mameworld.net has a whole forum dedicated to it and there is a new version of it out and about.
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #4 on: October 23, 2005, 09:45:45 pm »
If you are into DOS fe's, Gamelauncher will let you specify ANY size font you want.
NO MORE!!
DemonBrew
« Reply #5 on: October 24, 2005, 09:55:11 am »
Is that something within the Layout setup? or in the AtomicFE setup program? or just in a text file somewhere?
Spartan
  • Last login:December 02, 2009, 07:09:38 pm
  • I like stuff!
    • The Municade
« Reply #6 on: October 24, 2005, 01:35:10 pm »
Here's another vote for MaLa.  I just switched over from Cocktail frontend (after 2 years on that and 2 years on ArcadeOS) and couldn't be happier.  This is by far the best front-end I have used thus far (especially as configuration goes).
For font size, you may have to tinker with the layout tool a bit, but it's not hard to do.
youki
    • Atomic Front End
« Reply #7 on: October 24, 2005, 03:02:44 pm »
You can change font size by modifying the layout using AtomicLayoutManager.
And/Or you change font aspect using AtomicManager on the "Advanced" tab modifying font X and font X ration parameter.
If you use AtomicLayoutManager and it complains about a .BMP file , just open the file Layout.png with paintshop pro or another graphic program and save as  layour.bmp in the same folder.
