Author Topic: Frontend layout blurred/unclear  (Read 1766 times)
neil324
  • Last login:October 07, 2013, 03:53:50 am
« on: October 17, 2005, 01:51:55 pm »
Im using atomicFE and no matter which layout i use at there stated resolution or different ones they always seem to be blurred/unclear most of the layouts are 640x480, one i have used was 320x200 i think and that was pretty good but a bad layout. Anyone give some advice or know where you get layouts apart from atomics main site
youki
  • Atomic Front End Creator
    • Atomic Front End
Re: Frontend layout blurred/unclear
« Reply #1 on: October 17, 2005, 03:16:50 pm »
Hi,
If you use the layout in the native resolution and native orientation it should not be blurred/unclear.
If you use it with a non-native resolution or orientation  you could have some stretrching effect due to the resizing.
In what resolution you want use Atomic?
I don't know other place where you can download layouts.
neil324
« Reply #2 on: October 17, 2005, 03:37:49 pm »
Dont mind what resolution i use as long as it looks OK. Even if its the native resolution it doesnt look right. When i run atomic on my PC through a monitor its perfect.
My cabinet is set up 640x480 32 colours in windows and then atomic runs at the same 640x480 which is the native resolution for the layout
youki
    • Atomic Front End
« Reply #3 on: October 17, 2005, 05:30:22 pm »
How do you connect your arcade monitor to your PC?
Do you use a ArcadeVGA or a TV out?
Anyway,  if you cabinet screen is a 15khz one , all vertical resolution above 288 will be blurred.
A 15khz screen like a TV or a Arcade one can not display 480 lines. So if you use that kind of resolution it will be interlaced  , and the result is not very nice.
If you have an arcadeVGA , use 640x288 resolution.  If you don't have one use 320x240.
But as i don't have lot of layout native in 320x240 , it will be strechted so text will be not perfect. I suggest you make (or adapt) your own layout to the resolution 320x240.
this problem is not linked to Atomic. It will be the same for all Front End if you use 640x480 or above resolution on a 15khz monitor.
neil324
« Reply #4 on: October 18, 2005, 04:03:00 pm »
OK much clearer now, i had windows set at 640x480 and set the V hold to this so the windows boot screen would not roll but now ive changed it to be the same as the layout 640x288 and set the V hold to this it now rolls  :(
Minwah
    • MAMEWAH
« Reply #5 on: October 18, 2005, 06:04:46 pm »
Try a low-res mode with 240 lines (as opposed to 288).  These modes have different refresh rates, whereas 640x480 interlaced should be the same as say 320x240 (60hz).  So it should be much easier to get the v-hold right.
Edit: personally I use 368x240
