Author Topic: mala frontend how to add other emulators to  (Read 8336 times)
grayxx
  • Last login:July 27, 2006, 07:25:32 am
« on: October 17, 2005, 01:20:04 pm »
hi guys,
how do you add another emulator to mala, im using mame without any problems, but im wanting to add a snes emulator so i can play them games also in my cocktail cabinet, in vertical mode  ???
grayxx
Re: mala frontend how to add other emulators to
« Reply #1 on: October 17, 2005, 07:02:21 pm »
got it i didt have the rom extension correct now its working but the games arnt vertical,like the mame games, there is an option to have mame rotate with mala when the game starts, but no option to have the snes emulator rotate with mala, any ideas guys on how to make the snes emulator rotate wit mala?????
loadman
    • MaLa
« Reply #2 on: October 17, 2005, 07:11:26 pm »
Mala does not rotate MAME. It alters mame.ini so that mame runs in vertical mode.
The real question is: Does the snes emulator have a rotate option that you can apply?
grayxx
« Reply #3 on: October 17, 2005, 07:33:18 pm »
i c what you mean, so it alters the .ini when i select rotate mame with mala then?? so how do i go about making the snes emulator rotate with mala ??? the problem is when you add a second emulator to mala ther is no rotate with mala option for that emulator. is there any snes emlators that have a rotate option??
« Last Edit: October 18, 2005, 04:26:03 am by grayxx »
