Author Topic: Ground Wiring  (Read 2443 times)
omadon667
  • Last login:December 11, 2003, 11:15:34 am
Ground Wiring
« on: January 16, 2003, 06:04:15 pm »
Ok, I'm going to be installing my new IPAC this evening, and just wanted to verify one thing.
When wiring the grounds, I can daisy-chain them all together.
I know this isn't the best solution, as it could be prone to failure, and dificult to troubleshoot. A wiring block would be the best solution, from what I understand, but I just wanted to make sure it would work this way. I am totally off base here?
Thanks in advance.
Omadon
JLR2000
  • Last login:December 28, 2025, 10:50:05 pm
  • There is NO Sanctuary...
    • WWW
Re:Ground Wiring
« Reply #1 on: January 16, 2003, 06:15:13 pm »
Yes it will work.
From the IPAC site:
Found on this page:
http://www.ultimarc.com/ipac2.html
Good Luck.
rampy
  • *shrug*
  • Last login:March 02, 2007, 11:32:16 am
  • ...as useless as a JPG is to Helen Keller
    • Build Your Own PVR
Re:Ground Wiring
« Reply #2 on: January 16, 2003, 06:18:26 pm »
Thanks in advance.
Omadon
I wouldn't say it was prone to failure... but  what I think most people do is 1 loop for each side of the control panel (i.e. one for player 1's controls/buttons  1 for player 2's) That;s the convention anyways.,
Doing the looped ground also helps you troubleshoot where a breakage does occur.
good luck with your project!
Rampy
eightbit
  • Last login:September 07, 2019, 07:38:11 pm
  • My cab is never done...
Re:Ground Wiring
« Reply #3 on: January 16, 2003, 06:38:18 pm »
If you connect the ground full circle you have to have 2 failures to have a prob. Most people daisy chain the ground.
My statements are my own opinions. They have the value that the reader gives them. My opinion of my opinion varies between foolish and brilliant and these opinions often change with new information.
Silverwind
  • Last login:September 26, 2022, 12:49:09 am
Re:Ground Wiring
« Reply #4 on: January 16, 2003, 06:41:06 pm »
Any problems if you wire them all to a terminal block?
rampy
  • *shrug*
Re:Ground Wiring
« Reply #5 on: January 16, 2003, 06:41:47 pm »
Er that's what i meant... it's clear that i'm delarious, and will stop dispensing with advice for tonight... =)
rampy
OSCAR
  • Last login:September 06, 2018, 11:31:53 pm
  • I think Bigfoot is blurry, that's the problem...
    • Oscar Controls
Re:Ground Wiring
« Reply #6 on: January 16, 2003, 06:41:50 pm »
This is what I do, so there aren't any problems unless you happen to have two breaks.   I've never had a problem yet.
eightbit
Re:Ground Wiring
« Reply #7 on: January 16, 2003, 06:45:59 pm »
By terminal block I assume you mean a ground block. You need a block that connects all the wires to a common one. This is a great way to go but most people don't bother.
JLR2000
    • WWW
Re:Ground Wiring
« Reply #8 on: January 16, 2003, 07:04:50 pm »
For my upright cab I used a ground block with my Hagstrom encoder.  Check my photo pages linked on my site for examples.  It works well, but it is more work.  Using an IPAC in my cocktail project right now and I will be chaining the grounds.....
