Author Topic: dc control hack???  (Read 12826 times)
mo1e
  • Last login:May 28, 2013, 10:07:02 am
  • Do the happy dance
dc control hack???
« on: October 10, 2005, 05:44:33 pm »
hey all i knew i had a question but i forgot to ask until i looked at my dc controller and remembered. Its about the triggers when i took my control apart i noticed that there seems to be a magnet on the trigger that gets closer to a black chip thing on the other side. Now my theory is that when the magnet gets closer it pulls and that black chip can sense it there for the harder the trigger is pulled the greater the effect is this correct? Also how would i then hack the trigger buttons?
Thanks in advance carl
elvis
  • penguin poker
    • StickFreaks
Re: dc control hack???
« Reply #1 on: October 11, 2005, 02:25:12 am »
DreamCast pads use a Hall Effect joystick for the analogue controls:
http://en.wikipedia.org/wiki/Hall_effect
The beauty is that the voltage is the greatest when the buttons are pressed all the way in.  Hacking these are therefor VERY simple, as you can just remove the magnets and treat the shoulder buttons as digital devices (a closed digital circuit being the same as a full depression of the shoulder button).
Simple as that. :)
mo1e
« Reply #2 on: October 11, 2005, 03:03:10 am »
yes thats what i thought to do because after all i have never played an arcade game where pressure to the buttons is the key to win
mo1e
« Reply #3 on: October 11, 2005, 04:02:49 am »
but how would that be done to make it digital theres no pad to connect the wires?
  • Last login:January 30, 2026, 04:39:53 pm
« Reply #4 on: October 11, 2005, 05:24:54 am »
Here you go!  ;)  (click on the link to make the picture bigger)
« Last Edit: October 11, 2005, 05:27:08 am by HarumaN »
mo1e
« Reply #5 on: October 11, 2005, 06:10:59 am »
ok so i see all the red x,s are where i should solder the wires from my buttons and joysticks
« Reply #6 on: October 11, 2005, 06:35:24 am »
That is correct.  I hope this has cleared matters up for you.  :)
dennis808
  • Last login:May 13, 2021, 08:40:00 am
  • Holy Sanwa-sticks!
« Reply #7 on: October 11, 2005, 06:45:39 am »
yes sir!  For the shoulderbuttons the upper left part of the chip needs to be soldered, be sure you don't solder any other contacts and you'll have digital shoulderbuttons.
I used an exacto knife to scrape some of the black goop off all the regular connection points so that the underlying copper was visible. The solder won't hold onto the black stuff unless you scrape it first.
here's a blurry close-up of how mine came out:
"Complexity is the process by which the obvious is obscured by the irrelevant." -HSW
« Reply #8 on: October 11, 2005, 07:04:18 am »
Be careful that you don't cut through any of the traces...  I like to use a dremel tool (at medium/low speed) with the wire brush to remove the black coating.
mo1e
« Reply #9 on: October 11, 2005, 05:31:46 pm »
got my cp artwork delivered today :) and i have a sheet of mdf. My dc controlls are uncased and ready to be attempted to be hacked all i need now is the wire kit and my buttons/joysticks to arrive :D
Minwah
    • MAMEWAH
« Reply #10 on: October 12, 2005, 06:29:22 am »
Be careful when soldering next to the little chips for the triggers.  One of mine came off when I did it  ::)  Seems to still work tho...
mmmPeanutButter
  • Last login:December 20, 2020, 07:49:09 am
  • better living through gaming
« Reply #11 on: October 13, 2005, 11:28:48 am »
I was wondering this exact same thing...
Amazing photo HarumaN.  I guess that's why they call you the Supreme Solder King!
This is exactly what I needed.
mo1e
« Reply #12 on: October 13, 2005, 01:19:32 pm »
ok my pads are down to the circuits and my wires and buttons arrived today so tomorrow i can go up town buy a solder kit and be on my way :) hopefully
« Reply #13 on: October 13, 2005, 04:21:25 pm »
mo1e
« Reply #14 on: October 14, 2005, 01:55:02 am »
got work to go  to then will give it ago after  i mite need u haruman  ;D
« Reply #15 on: October 14, 2005, 05:07:58 am »
I'll be here...  :P
mo1e
« Reply #16 on: October 15, 2005, 05:01:14 am »
hi im sorry about the poor quality of pictures here i hope you can see them. My wires turned up yesterday im sure i recieved all i need but all i got was one thick wire that contained 4 wires like this
(there are 4 wires the other thing is fabric)
each of the four wires was actually 2 wires twisted like this
do i seperate them to make 8 wires?
in total for the up, down, left, right, a, b, and other buttons etc i will need 11 wires i think.
I also recieved a bundle of thin wire like this
 and some crimps is the thin wire the grounding wire?
Goz
  • KOTA
« Reply #17 on: October 15, 2005, 05:22:14 am »
Good thing you put descriptions. I had no idea what they were actually pictures of.
mo1e
« Reply #18 on: October 15, 2005, 05:26:09 am »
yer thats what i meant about the visibility the cameras gone c*ap all of a sudden. can you help?
Goz
  • KOTA
« Reply #19 on: October 15, 2005, 07:21:11 am »
hoestly I cannot make out anyting in the pics. By you r description you bought twisted pair wire. There is no problem with using the stuff, but yeah it is two wires interlooping / twisting. So one braide is two wires or you have a total of 8 wires.
You need 12 wires
Joy
1 - right
2 - up
3 - down
4 - left
5 - start
6 - ground
Buttons (will also use ground)
7 - X
8 - A
9 - Z
10 - Y
11 - C
12 - B
Of course doesnt matter what order. I simply used the numbers so you wouldn't have to count.
hope this helps,
-Goz
« Reply #20 on: October 15, 2005, 07:22:03 am »
umm, where did you buy those wires from? ?
And yes you will 11 wires for buttons and directions.  You will need one long wire with daisy chained female disconnects for your common ground.
mo1e
« Reply #21 on: October 15, 2005, 07:27:27 am »
from grumby on ebay are these wires correct?
Goz
  • KOTA
« Reply #22 on: October 15, 2005, 07:31:59 am »
Looks like he bought this Kit which is CAT 5 cable with the ends cut and the inulating jacket in tact.
« Reply #23 on: October 15, 2005, 07:36:46 am »
They are correct.  I was just curious as to where you got them.  That's a pretty good deal, IMO.  :)
mo1e
« Reply #24 on: October 15, 2005, 07:38:55 am »
ok so is this correct the daisy chained ground wire goes to the red circle and the button wires go to the blue circle
mo1e
« Reply #25 on: October 15, 2005, 07:48:56 am »
or vice versa?
Goz
  • KOTA
« Reply #26 on: October 15, 2005, 07:57:24 am »
Typically the ground goes to the common (red in your picture)
mo1e
« Reply #27 on: October 15, 2005, 08:02:59 am »
ok so i use the thin wire to ground? and the 8 wires in the one sleeving wont be enough so i take it i use the 8 wires then cut another bit off and use 3 wires from this?
mo1e
« Reply #28 on: October 15, 2005, 08:03:57 am »
and yes thats the kit i bought :)
« Reply #29 on: October 18, 2005, 12:54:14 pm »
So how's the DC hacking going??
mo1e
« Reply #30 on: October 18, 2005, 01:10:54 pm »
lmao not even given it a go yet i got my solder kit though im waiting for the wood for the cp
mo1e
« Reply #31 on: October 18, 2005, 01:40:48 pm »
also why does there have to be a ground daisy chain? and should it be done like this
or like this
That mite sound dumb but im unsure about this
mo1e
« Reply #32 on: October 18, 2005, 01:51:06 pm »
and also does the black goop neex scraping off the connections?
mo1e
« Reply #33 on: October 18, 2005, 02:52:40 pm »
ok i now officially take back my words ( anyone can solder cant they) i can solder but the solder never seems to stick to the dc connectors anyone help?
« Reply #34 on: October 18, 2005, 03:08:29 pm »
Ok...
First, did you scrape/sand the black stuff off of the contacts?
Second, are you using solder with a flux core?
Also, your ground needs to be like the first picture (daisy chain).  Creating a loop like in your second picture can and most likely will cause problems.
« Last Edit: October 18, 2005, 03:10:01 pm by HarumaN »
mo1e
« Reply #35 on: October 18, 2005, 03:12:09 pm »
ok thanks for that and yes i did scrape off the goop and the solder is a no clean solder (doesnt neeed to be water washed afterwards)
« Reply #36 on: October 18, 2005, 03:19:52 pm »
Does that mean the solder has no flux?  If so, you're gonna need some (either flux paste, or solder with a flux core).
I use solder with a flux core and I never have to clean the board when I'm done.
mo1e
« Reply #37 on: October 18, 2005, 03:27:07 pm »
brb let me check all i know is at work some solders we have to clean the boards afterwards i will go check now k
mo1e
« Reply #38 on: October 18, 2005, 03:28:13 pm »
yer its a no clean core solder 1.1% flux i can see the flux when the solder is melted
« Reply #39 on: October 18, 2005, 04:04:49 pm »
Hmm...  your solder should be sticking.  Do you see copper underneath of where you scraped the black off?  (Hopefully you didn't scrape the copper off as well.)
You may try wiping down the points where you wish to solder with rubbing alcohol.  This may help.
