Author Topic: Cleaning joysticks  (Read 1039 times)
Bomber
  • Last login:July 20, 2006, 01:48:39 am
Cleaning joysticks
« on: October 03, 2005, 10:21:32 pm »
I've just picked up a couple of joysticks and their pretty filthy.
So I was wondering what you good folks use to clean up joysticks?
Can I just pull it apart and put them in soapy water as long as I rinse and dry all the pieces properly before putting it back together? Or should I use some sort of metal cleaner?
Never get into fights with ugly people - they have nothing to lose.
stratjakt
  • Last login:October 16, 2006, 11:43:58 am
Re: Cleaning joysticks
« Reply #1 on: October 04, 2005, 12:01:29 am »
Formula 409 or Fantastik work great for plastic bits..
I usually soak stuff like that for a while in warm water with some dish detergent to loosen the grime, then give it a good wiping afterwards with the 409 and some paper towels..
Stingray
« Reply #2 on: October 04, 2005, 04:51:40 pm »
Simple Green works well on plastics too.
-S
TOK
  • The Game Always Wins
« Reply #3 on: October 04, 2005, 06:31:08 pm »
-S
I'd add the small caveat to test the material you're using it on first. Straight Simple Green is tough on plastic and rubber. It will dry out and discolor some soft plastics and rubber.
Bomber
« Reply #4 on: October 04, 2005, 07:01:03 pm »
Thanks for the feedback guys. I'll see what I can find down at the hardware store.
Stingray - love the footer. Although someone who dresses like that probably deserves to be locked up....
