Author Topic: dreamcast cdrs or can you use dvds?  (Read 2938 times)
mo1e
  • Last login:May 28, 2013, 10:07:02 am
  • Do the happy dance
« on: October 01, 2005, 03:23:11 am »
hi i have dreamsnes on my pc all i need to do is burn the roms to a disk i have done this before using a cdr but i was just wundering is it possible to use a dvd disk?
SNAAKE
  • Trade Count: (+29)
  • Last login:Today at 05:48:43 pm
  • my joystick is bigger than your joystick !
Re: dreamcast cdrs or can you use dvds?
« Reply #1 on: October 01, 2005, 03:33:04 am »
cdr only
mo1e
« Reply #2 on: October 01, 2005, 03:34:52 am »
damn lol maybe 2 disks are needed then
  • Last login:July 23, 2025, 07:04:20 pm
« Reply #3 on: October 01, 2005, 07:37:33 am »
Also, know that while cd-r's work, cd-rw's will not.
Scott84
  • Last login:May 17, 2022, 08:24:59 pm
« Reply #4 on: October 01, 2005, 08:31:53 am »
GD-Roms work too!  :D
"Computer games don't affect kids, I mean if Pac Man
affected us as kids, we'd all be running around in
darkened rooms, munching pills and listening to
repetitive music." -- Marcus Brigstocke
spiffyshoes
  • Last login:September 20, 2015, 01:24:46 pm
« Reply #5 on: October 01, 2005, 10:34:55 am »
Oh and DreamSNES runs a little slow.  Maybe if you overclocked the DreamCast it would work better.  I don't know.
Grasshopper
  • Last login:March 04, 2025, 07:13:36 pm
« Reply #6 on: October 01, 2005, 12:43:00 pm »
I read somewhere that cd-rws can be made to work if you adjust the laser. I haven't tried it myself though.
Goz
  • KOTA
« Reply #7 on: October 01, 2005, 03:02:43 pm »
My overclocked DC plays games via DreamSNES just fine.
« Reply #8 on: October 01, 2005, 03:14:58 pm »
It can be done, but it will cause the laser to burn out about 4 times as fast as normal.
« Reply #9 on: October 02, 2005, 08:59:36 am »
How did you overclock your DC?  Is there a guide for this somewhere?
Franco
« Reply #10 on: October 02, 2005, 11:30:46 am »
I was thinking the same thing and found a guide here > http://devcast.dcemulation.com/mods/overclock/overclock.php
I have never overclocked anything though so i dont know whether to try it or not. I have two DCs though so I may give it a go. I need to check which versions I have got as it only seems to work on 0 and 1 models (not 2). I think you also need a 40hz quartz crystal? Im not to sure on this, im sure the mighty DC master Gozur will sort us out  ;)
« Reply #11 on: October 02, 2005, 11:57:52 am »
Yeah, I found that same guide, too...  hopefully Goz can clarify it.  :)
Goz
  • KOTA
« Reply #12 on: October 04, 2005, 11:18:46 am »
I actually purchased my Dreamcast overclocked. The guy that I got it from used to provide an overclocking service for the DC. I know him from the SHMUPS forum. Last time I chatted with him; he was looking into getting the stuff to begin overclocking again. The one I have is in a custom case with a switch to toggle betwwen 200Mhz and 243Mhz. I've never found a reason to turn off the overclock and I was assured that the overclock would not fry the CPU. There is a distinct difference in playing SHMUPS with the overclock on vs off.
mo1e
« Reply #13 on: October 04, 2005, 05:27:25 pm »
thats odd dreamsnes seemed to work fine on mine no lag
elvis
  • penguin poker
    • StickFreaks
« Reply #14 on: October 04, 2005, 06:37:45 pm »
CD-R, DVD-R, CD-RW and DVD-RW all use different types of lasers.  Any PC-based CD/DVD burner actualy has 3-4 different lasers in it, depending on what it supports (hence why they take so bloody long to figure out what gets put in them when you load a new disc up).
The DreamCast laser can read CDROM and GDROM.  AFAIK GDROM is simply a double-density CDROM, hence why CDROM still works fine in DC's without a mod.
Modding a DreamCast to read anything other than CD-R will do damage to it over time.  Not to mention the fact that CDs can be purchased for mere cents these days, why the heck would you bother risking the life of your DreamCast's laser (meaning  you have to fork out for a new laser, or a whole new DreamCast) compared to spending a few bucks on 100 CD-Rs?
