Author Topic: How do I mount this coin door?  (Read 2171 times)
KungFuJoe
  • Last login:February 05, 2006, 05:10:10 am
« on: September 28, 2005, 06:36:24 pm »
I bought this off ebay but I guess I should have checked to see if it came with a mounting frame...which it didn't.
spystyle
  • Thanks alot, now I have to build a time machine and warn myself yesterday!
  • Last login:February 23, 2021, 02:30:18 pm
Re: How do I mount this coin door?
« Reply #1 on: September 28, 2005, 06:47:59 pm »
I mounted a coin door without a frame and it works just fine.
Dig it?
Craig
« Last Edit: December 09, 2006, 11:20:57 am by spystyle »
whammoed
  • Last login:March 13, 2026, 12:48:37 pm
  • Crack don't smoke itself
    • NiceMite
« Reply #2 on: September 28, 2005, 07:16:11 pm »
Before you mount it you may want to buy her dinner first, maybe even a movie. ;)
Seriously though, If you are good with a router looks like you could cut an appropriate size hole for that door and use some long screws (pilot hole first) to mount it.
KungFuJoe
« Reply #3 on: September 28, 2005, 07:23:28 pm »
Hmm...and you don't worry about it ripping out of the MDF with the screws being so close to the edge?
spystyle
« Reply #4 on: September 28, 2005, 07:28:28 pm »
I wouldn't worry about it at all, 3/4" MDF is tough stuff.
Use washers on the back.
Maybe if you remove the coin door guts you can place it flush against the material and trace it. Then match it with hole saws and jigsaw, or router with straight cutting bit.
Good?
Craig
whammoed
    • NiceMite
« Reply #5 on: September 28, 2005, 07:33:34 pm »
Well, if you go with the way spystyle did, no.  You will be bolting it through the mdf.  If you want the hinge to be mounted to the edge of the mdf, maybe.  Depends how often you want to open it up and yank on it.  Mount it the way spystyle did and no worries.
SeanCyrusTowel
  • Last login:January 09, 2011, 08:42:33 pm
  • 42
« Reply #6 on: September 28, 2005, 10:44:32 pm »
man, that was the coin door I was bidding on a few weeks ago  ;) at least it went to a fellow BYOACer  :D
KungFuJoe
« Reply #7 on: September 28, 2005, 11:53:04 pm »
Well...if we were both bidding on the same item, I'm glad you didn't go too high.  I had just gotten outbid on a couple other coin doors and I REALLY wanted this one (since I have a 4 player cab)...and I'm already way over "budget".  :)
SeanCyrusTowel
  • 42
« Reply #8 on: September 29, 2005, 12:16:35 am »
LOL, yeah, I didn't want to pay more than 50.... plus I haven't even started mine yet :P
