Author Topic: frontend for 1964 and epsxe  (Read 2217 times)
starcrudph
  • Last login:April 04, 2006, 05:43:30 am
« on: September 26, 2005, 08:45:35 pm »
hi. im planning on using 1964 and epsxe emulators in a cabinet. what frontend should i use? or has somebody tried this? also, what os would you recommend for this setup ? thanks.
beek
  • Last login:March 22, 2020, 11:25:49 am
Re: frontend for 1964 and epsxe
« Reply #1 on: September 26, 2005, 08:58:54 pm »
I couldn't get the command line switches to work with 1964.  Ended up using Project64.  They are pretty similar as they use the same plugins.  oh and I'm using Mamewah.
starcrudph
« Reply #2 on: September 26, 2005, 09:07:29 pm »
thanks. ok i will try. i just dont know how to setup epsxe on mamewah, is this fairly easy to understand, im currently using dos advmenu/advmame.
JonnyBoy
  • Last login:November 12, 2009, 01:59:00 pm
  • Inka Dinka Do
« Reply #3 on: September 26, 2005, 10:21:10 pm »
GameEx is incredibly easy to set up but can require a hefty PC. I really like it.
www.gameex.net
I had to beat them to death with their own shoes...
youki
  • Atomic Front End Creator
    • Atomic Front End
« Reply #4 on: September 27, 2005, 03:51:36 am »
You can try Atomic too , it works.
Never tried with 1964 , but Project 64 is ok. and epsx too.
WTB
  • Last login:May 09, 2019, 10:15:35 pm
    • ihateyourband.net
« Reply #5 on: September 28, 2005, 05:04:24 am »
GameEx
   -Matt
pmc
  • Last login:December 20, 2023, 07:43:02 am
    • website
« Reply #6 on: September 28, 2005, 05:55:02 am »
Do some searching in this forum. That's how I learned how to set up ePSXe under Mamewah. If I recall, I'm not calling the .EXE. I call a .BAT file that calls the .EXE with correct arguments (to pass the game image file) and formatting.
I also use Project64 under Mamewah. Works great.
-pmc
starcrudph
« Reply #7 on: September 30, 2005, 09:18:27 am »
ok thanks. will using xp be a problem when using it as an os for a cabinet? or will litexp solve that for us?
pmc
    • website
« Reply #8 on: October 01, 2005, 03:34:36 am »
I don't think it matters. I'm running W2K Pro.
-pmc
