Author Topic: ambient sounds while in games  (Read 1498 times)
Scoobie
  • Last login:December 26, 2024, 12:53:48 am
« on: September 25, 2005, 10:43:25 pm »
I'm using Mamewah v 1.60 and have the Ambient Arcade sounds playing while browsing the game list.  However now I'd like to have the Ambient Arcade sounds play while I'm playing the games too.
I searched the boards, but didn't find a match.  Does anyone know how to make this happen?
creatine28
  • Last login:July 26, 2012, 03:41:48 pm
  • Which way to the Arcade?
Re: ambient sounds while in games
« Reply #1 on: September 25, 2005, 11:56:18 pm »
I was lookin for the same thing and I dont believe Mamewah does that, however emulaxian 3d frontend does that, at least in the older versions!
http://3darcade.mameworld.net/
  • Last login:Yesterday at 07:46:44 pm
« Reply #2 on: September 26, 2005, 12:14:00 am »
Do some research.... this type of thing has been gone over several times in the forums.
Long story short, we all dropped support for it because it eats up resources and all-in-all it's a bad idea anyway.
)p(
  • Last login:March 27, 2009, 03:38:15 am
  • We are the Galaxians...
    • Emulaxian:cabinet and frontend
« Reply #3 on: September 26, 2005, 09:50:42 am »
Actually for once I have to disagree with HC...  :o ;)
I only have pre 90 games on my cab. And for those resources are more thne enough. Therefore I still use this feature... :)
peter
Scoobie
« Reply #4 on: September 26, 2005, 06:00:28 pm »
FTMP I'm doing the same, only I'd like to use it with Mamewah.
TheGatesofBill
  • Last login:August 22, 2018, 09:07:04 am
« Reply #5 on: September 26, 2005, 09:16:26 pm »
Of course the easiest way is to burn it to CD and stick a cheap Discman and a second set of powered speakers in your cab. Put the CD player on repeat, hit play, and tada! Ambient sounds all the time. When your done playing just turn off the CD player and/or speakers or just turn the volume all the way down.
Scoobie
« Reply #6 on: September 28, 2005, 10:00:30 pm »
Well, the easiest thing seems to be adding a shortcut to the ambient sound file and dropping it in my startup folder.  The downside to this is I can't change the volume of the loop while in Mamewah, just the volume of the games...I'll play with it like this for a while and see how I like it. ;D
TheGatesofBill
« Reply #7 on: September 28, 2005, 11:45:38 pm »
Check my post, its even easier, and you have volume control, and it doesn't use any CPU time. The best solution isn't always a software one.
Scoobie
« Reply #8 on: September 29, 2005, 04:39:40 pm »
I didn't want to use an external audio device for this.
