Author Topic: Question about joysticks  (Read 1659 times)
mrbasdf
  • Last login:January 16, 2004, 12:26:50 am
  • You are warm hungry!
« on: January 13, 2003, 12:06:41 am »
I have an arcade stick, with a competition joystick. I was recently at the arcade, playing Marvel vs. Capcom 2, and noticed that the joystick was not very stiff, as opposed to the competition joystick. I think it was a perfect 360, since i couldn't hear any clicking of microswitches. Does anyone know what kind it is?
You must have confused me with a clown who gives a damn.
rampy
  • *shrug*
  • Last login:March 02, 2007, 11:32:16 am
  • ...as useless as a JPG is to Helen Keller
    • Build Your Own PVR
Re:Question about joysticks
« Reply #1 on: January 13, 2003, 01:17:22 pm »
I know not what a MVC2 arcade cabinet uses as a stick (plus if it's a conversion there would be no way to tell) I'm not sure that the absence of audible clicking makes it a perfect360 (maybe it's a well sealed control panel or a noisey arcade or ???)
what I can offer up is if your joystick is too stiff or to "easy" that perhaps you could change the spring in it to adjust the tension to more your likeing (if you can find suitable springs in a local hardware store I belive therealbobroberts has 'em failing that happs?)
*shrug* ymmv good luck
rampy
