Author Topic: what tv and is it ok  (Read 1655 times)
mo1e
  • Last login:May 28, 2013, 10:07:02 am
  • Do the happy dance
« on: September 23, 2005, 08:58:48 am »
hi all basically i am going to attempt to put my xbox into a cabineyt and use a homemade arcade control with an xbox adapter but i was just wundering a conventional tv would work on this right? it will connect through the scart socket like normal and also what sizes are ok for the tv?
mo1e
Re: what tv and is it ok
« Reply #1 on: September 23, 2005, 06:41:26 pm »
anyone help me?
dmsuchy
  • Last login:August 29, 2025, 01:27:50 pm
  • I kill communist llamas for fun.
« Reply #2 on: September 23, 2005, 07:40:40 pm »
We realy don't have SCART here in the States as of yet, but as long as you have a SCART adapter for your Xbox any TV with SCART should be fine.
mo1e
« Reply #3 on: September 25, 2005, 02:42:38 pm »
hi is a 28inch tv too big or too small? and also will a cabinet be able to hold it?
Jess--
  • Last login:April 05, 2023, 09:51:55 am
    • My Botched Cab
« Reply #4 on: September 26, 2005, 06:51:26 am »
the average arcade cabinet will take the weight of pretty much any tv you can fit into it as they are built to withstand the weight of a standard arcade monitor + people hitting them when they lose (we've all done it), as for whether its too big or too small that is all down to personal preference and how big YOUR cabinet is. the basic slim jamma cabinets tend to use 20" monitors, larger machines (mortal kombat, SFII etc) tend to use 25 / 26" monitors.
if you are planning on using a standard TV and your Xbox I would suggest that you find yourself one of the older FST toshiba TVs,
they come in sizes from 17" up to 26"
They do not have a perfectly flat screen (flat screens never look right on arcade cabinets)
they have a slim border to the top & sides of the screen (making them ideal for dropping into a cabinet)
they also have plenty of inputs (2x scart + 1 SVideo) allowing other things to be connected aswell (ps2 / dvd etc)
both scarts support rgb input and they dont suffer with ghosting from the tuner side coming through on the scarts (many modern / cheap tvs ghost from the tuner through to the scarts).
mo1e
« Reply #5 on: September 26, 2005, 09:49:15 am »
ok thanks for that :)
