Author Topic: Speaker Grill Material  (Read 3388 times)
southpaw13
  • Last login:August 17, 2025, 03:18:15 pm
  • Whatever!
« on: September 22, 2005, 08:21:11 am »
Where do you find the material used to make speaker grills?  I am looking for a sheet of it....
Thanks,
Southpaw
teef two
  • Last login:November 24, 2006, 08:21:45 am
  • Mmmmame
Re: Speaker Grill Material
« Reply #1 on: September 22, 2005, 08:22:27 am »
A lot of people buy those wire waste paper bins and cut the grills out from those. Honestly.
Ken Layton
  • Guru
  • Technician
« Reply #2 on: September 22, 2005, 10:02:14 am »
Metal or cloth? If cloth try www.grillcloth.com
If metal use screen door material.
southpaw13
  • Whatever!
« Reply #3 on: September 22, 2005, 10:04:20 am »
I'm looking for something that can be used on the outside of the cab.  More sturdy, similar to a Dragon's Lair speaker grill...
Southpaw
southpaw13
  • Whatever!
« Reply #4 on: September 23, 2005, 12:10:10 pm »
This is what I am looking for....any suggestions?
Thanks,
Southpaw
stratjakt
  • Last login:October 16, 2006, 11:43:58 am
« Reply #5 on: September 23, 2005, 02:15:12 pm »
Have a look here http://www.mnpctech.com/modsupplies.html, check out the "modders mesh".  It's basically a metal grille-like stuff, I think its aluminum, its easy to bend and form..
BSR
  • Last login:January 09, 2006, 07:52:00 pm
  • I'm a lurker
« Reply #6 on: September 26, 2005, 04:18:19 pm »
The material you're looking for is called ABS (Acrylonitrile-Butadine-Styrene) pastic with a textured hair-cell finish. You should be able to get a quarter sheet for under $10, but without the holes.
I never found a place that offered perforated holes for ABS. The places that do perforated hole plastics usually just use polypropylene or PVC which are not the right type of material. Polypropylene is a clear/translucent material; smooth on both sides.
I did find a place that does metal perforating that would be willing to do a sheet of ABS if I shipped it to them.
In the end, I decided to just drill the holes myself since the piece I needed was fairly small.
Crazy Cooter
  • Senator Cooter was heard today telling the entire congressional body to STFU...
  • Last login:August 19, 2025, 11:29:13 pm
« Reply #7 on: September 27, 2005, 12:49:32 pm »
My local hardware store carries that.
tivogre
  • Last login:July 18, 2013, 09:13:34 pm
    • ogredog.com
« Reply #8 on: September 27, 2005, 05:17:20 pm »
I used one of the metal mesh trash cans.
I routed a recess in the speaker panel and tacked the mesh down with staples:
Then I "painted" the mesh with 2 part epoxy, bringing it to s smooth surface level with the surrounding wood:
After a final touch up with Bondo to completely smooth it out:
I painted the panel black:
And then covered it with black grill cloth:
This is what you see looking up at the finished speaker panel:
It's extremely acoustically transparent, and protects the speaker cones very well.
Way more detail is on the construction web site:
http://www.ogredog.com/mame_construction_home.htm
...staring around day 13.
southpaw13
  • Whatever!
« Reply #9 on: September 27, 2005, 06:17:08 pm »
That's cool, but I wanted to get away from using speaker cloth.  I wanted some type of material that would just screw in and look finished.  I also noticed that material I'm looking for on Atari cabs like kangaroo...
Basically the same stuff as a regular metal speaker grill from a car but in sheet form...
Thanks,
-Southpaw
