Poll
Where should remote monitor controls be mounted?
Accessible through the open control panel.
2 (25%)
Accessible through the coin door.
5 (62.5%)
Other (explain in post)
1 (12.5%)
Total Members Voted: 8
Author Topic: Where to mount remote monitor controls?  (Read 1104 times)
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« on: September 21, 2005, 12:00:38 pm »
My monitor has one of those "remote" adjustments. Not remote in the wireless "tv remote control" sense, but in the arcade monitor sense that the knobs are on a seperate little board that can be mounted somewhere convenient and accessible from the front.
To anyone who has this kind of set-up, I'd like to know where you mounted it? As I see it, I have two options:
1. Mounted somewhere accessible when the control panel is opened.
 or
2. Mounted somewhere accessible through the coin door.
Opinions? I've made a Poll. Please vote.
NO MORE!!
MameJunkie
  • Last login:March 19, 2009, 08:23:45 pm
  • Eeeeeeeevil
Re: Where to mount remote monitor controls?
« Reply #1 on: September 21, 2005, 04:03:50 pm »
I put any controls that isn't needed often within easy reach through the door.  I just think that opening the door is often times easier than removing/opening some of the CPs.
Reguardless where, I would 'hide' it from plain view.
Teamwork - A group of people running around doing what I say.
Level42
« Reply #2 on: September 21, 2005, 04:23:27 pm »
My cab came with a monitor with a "remote control" installed in the coin door, and I think that's the most logical place, at least for this cab, since I have to open the CP hinges through the coin door to get acces to the CP room, so this would require a lot more work to get to it...
Minwah
    • MAMEWAH
« Reply #3 on: September 21, 2005, 06:48:05 pm »
Mine is also behind the coin door (along with USB2 hub, volume & system switch):
PedroSilva
  • Last login:August 01, 2018, 08:37:57 am
  • Grettings !
« Reply #4 on: September 21, 2005, 06:59:22 pm »
Not yet done but on course ...
My problem is that the TV I use on my cab doesn't detect and automatically switch to the S-video input when powered on. Since it was the only thing I need from the remote I'll use a button on the CP to activate the input. I'm hacking a remote control and taking it appart so that I can place him wherever I want and then wire the button I need and the IR emitter placing them near the TV remote sensor (IR emitter) and near the button (on the CP).
It doesn't seem to be your exact problem, but if you need only two or tree buttons from the remote, you might want to consider this solution.
telengard
  • Last login:October 21, 2025, 02:12:46 pm
  • Yeah, it's a classic! 21+ on BYOAC and still goin
    • S T U R C A D E
« Reply #5 on: September 21, 2005, 07:11:45 pm »
I have mine on top of the cabinet right above the marquee.  Works well and is accessible without needing keys etc.
~telengard
S T U R C A D E     M.A.M.E. Cabinet
http://www.briansturk.com/mame.html
CrustyPresident
  • Last login:June 11, 2007, 08:55:40 pm
« Reply #6 on: September 21, 2005, 07:17:41 pm »
My dedicated Neo Geo has the remote mounted under the control panel. The biggest advantage of this is that while adjusting the controls your viewing the screen at the same angle as when playing. If the board is inside the coin door its more difficult to look at the monitor while adjusting it. The disadvantage is that it's harder to get to the controls.
-Scott
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
« Reply #7 on: September 21, 2005, 07:23:44 pm »
-Scott
Was going to say this exactly ... I prefer under the CP.
Cheers.
Working: Not Enough
Projects: Too Many
Progress: None
SUB ZERO
« Reply #8 on: September 21, 2005, 08:18:48 pm »
Mines mounted inside on the right side of the keyboard compartment  :)
