Author Topic: Trouble with Butler's Mamewah setup  (Read 1384 times)
DeLong20
  • Last login:September 10, 2010, 01:28:48 pm
« on: September 20, 2005, 01:03:07 pm »
After installing and running Butler's mamewah setup, I got a message saying I was missing fm20.dll.  I downloaded and installed fm20.dll.  I then rebooted and re-ran setup, only this time I got a message saying:
System error & h80070485 (-2147023739).  One of the library files needed to run this application can not be found.
Does anyone know what "library file" I am missing and where do I go from here to fix my problem.  I ran the search function on fm20.dll and no one else had this problem after they installed fm20.dll.  That and the message I recieved after I installed the .dll file, tells me that this may be a PC problem and not a setup problem.
Any and all suggestions are appreciated.
You mean I can type anything I want in here and it will show up?
Re: Trouble with Butler's Mamewah setup
« Reply #1 on: September 20, 2005, 05:40:37 pm »
I'm sorry I am not sure the answer...but do you really need MW Setup?  Do you know it only works up to version 0.97 of Mamewah?
DeLong20
« Reply #2 on: September 21, 2005, 09:39:05 am »
I guess technically no, I do not need to use MW setup.  It just makes things soooo much easier.  And yes, I do know it only works up to V0.97.  I started out using V1.16 but when it came to using Screamings set up, the setup required a bunch of items not nessasary for my machine ex. Internet Explorer 5 or higher, .net framework.  I am also working on a limited hard drive (8.4 gig) and processor (500 celeron).  I thought that V0.97 would be easier to use/setup and would be better suited for my limited PC.  I also work with a guy that has used and setup V0.97 and had no problems at all.
I am just wondering if anyone else had came across the same error message and might have a solution.  If it came down to it, I guess I can just set up V0.97 w/out a secondary setup program.
« Reply #3 on: September 21, 2005, 10:23:55 am »
OK just thought I'd ask.  Unfortunately Mr Butler hasn't been around for a while so we can't ask him :(
2600
« Reply #4 on: September 21, 2005, 10:57:23 am »
Didn't Butler's MAMEWah Setup require .NET as well?   Sounds like you don't have that installed.
« Reply #5 on: September 21, 2005, 06:39:21 pm »
I thought it was VB6, so no.  I'm not 100% sure tho.
