Author Topic: Mame32 & Screen Rotation  (Read 1273 times)
cincnorad
  • Last login:September 26, 2005, 11:26:16 pm
« on: September 19, 2005, 08:26:59 pm »
Just got a new cocktail table, and am LOVING it so far.
loadman
  • Last login:January 29, 2026, 07:18:10 pm
    • MaLa
Re: Mame32 & Screen Rotation
« Reply #1 on: September 19, 2005, 11:30:17 pm »
.....I've been down that road and tried many options. Mame 32 does not
« Last Edit: September 19, 2005, 11:31:50 pm by loadman »
juggle50
  • Last login:July 18, 2024, 07:25:48 am
  • Your either on the bus or off the bus
« Reply #2 on: September 20, 2005, 03:29:07 am »
I use the software program pivot pro to rotate windows and don't have any problems.  Also I've heard I-rotate is also a good program to rotate your operating system.  JMHO  good luck.
cincnorad
« Reply #3 on: September 21, 2005, 12:48:39 pm »
Thanks for the suggestions.
markb
  • Last login:April 30, 2011, 06:41:02 am
  • The One and Only.
« Reply #4 on: September 21, 2005, 04:19:47 pm »
I've just gone through the same as you are describing, I tried pivot pro, etc without good results also pivot pro requires quite a bit of resources.
There is however a compromise in that you can use mame32 to play the games but a seperate frontend to select them.
I use 3D Arcade as a front end and have it autoload on start up.
http://3darcade.mameworld.net/
You can set it up so that all of the menus are in vertical mode, the down side to this is that it does take some setting up but it has been well worth the effort.
loadman
    • MaLa
« Reply #5 on: September 21, 2005, 09:08:17 pm »
« Last Edit: September 21, 2005, 09:36:06 pm by loadman »
