Author Topic: Cabinet Painting Advice Needed  (Read 8839 times)
eggedd2k
  • Last login:February 14, 2006, 09:38:56 am
« on: September 17, 2005, 02:34:10 pm »
can anyone tell me the best methods/paints to use for painting my cab? it's made of MDF and I want basically the standard arcade machine finish to it.
any advice?
Abomination
  • Last login:December 07, 2023, 11:18:15 am
Re: Cabinet Painting Advice Needed
« Reply #1 on: September 17, 2005, 06:23:15 pm »
try this http://www.woodweb.com/knowledge_base/Highgloss_finish_on_MDF.html
if your not looking for high gloss there is more finishing techniques in there
tbombaci
  • Last login:October 31, 2024, 01:32:56 pm
« Reply #2 on: September 18, 2005, 12:49:55 am »
My steps:
1. Sand smooth with 220 grit
2. Prime with Kilz primer
3. Sand again with 220
4. light coat of Oil based semi gloss Rustoleum Painters touch
5. After a few hours, sand with 220
6. Repeat 4 and 5 as many times as you can stand it
7. Let dry for about a week
I use a gravity feed HVLP spray gun hooked up to my air compressor. The finish is amazing.
I ended up with 14 coats on a friends MAME machine. I did about 6 coats on my Centipede restoration.
-Tom
