Author Topic: WG U2575 Monitor  (Read 2787 times)
jaredhobbs
  • Last login:May 31, 2022, 10:07:01 pm
WG U2575 Monitor
« on: September 17, 2005, 11:06:29 am »
I posted to the BUY/SELL/TRADE forum looking for a chassis for my monitor and I received a reply that POSSIBLY  my med res monitor would work with a standard res chassis or dual res chassis. Does anyone know if that's possible? Here is the information on the monitor that was printed on the stickers:
WG 1568212
100-00812-05
A63AGD01X
04RC0154-008
120V 50/60Hz
2.0A max
The guy I bought it from said it needed a U2575 chassis (med res monitor). If anyone knows if this monitor is compatible with a standard res or dual res chassis, can you please point me in the right direction? Thanks in advance.
Jared
Ken Layton
  • Guru
  • Technician
Re: WG U2575 Monitor
« Reply #1 on: September 17, 2005, 12:15:37 pm »
All monitors look the same from the front.
jaredhobbs
« Reply #2 on: September 17, 2005, 05:28:03 pm »
Found some more info on the monitor. According to this website http://www.wellsgardner.com/wellsgardner31/supportdata/RELEASE%20NO%20BREAKDOWN.pdf
My monitor is a Wells Gardner K7500. Does anyone know if this monitor is compatible with a standard res or dual res chassis? Thanks,
Jared
Ken Layton
  • Guru
  • Technician
« Reply #3 on: September 17, 2005, 06:01:27 pm »
A k7500 monitor is medium resolution ONLY. It has a special yoke and is not compatible with other chassis. The k7500 is a current production model. You can purchase the chassis and neckboards as brand new "repair parts" complete straight from the parts department at Wells-Gardner.
Call the parts department at 1-800-336-6630 (or 708-290-2100) and order one each of the following:
# 054A7501-001 (or - 002 or -003) Main chassis board
# 025A1414-001  or 054A7501-004 Neck Board
