Author Topic: Project Popeye: Updated 01.27.06: FOR SALE  (Read 11121 times)
lebanull
  • Last login:April 17, 2017, 10:55:32 am
« on: September 15, 2005, 11:10:09 am »
I just wanted to take this time to say
« Last Edit: January 27, 2006, 03:05:26 pm by lebanull »
Re: My First Arcade Restore Project
« Reply #1 on: September 15, 2005, 11:33:02 am »
On the sound amp, is it an enclosed unit or a regular PCB?  When sound is complete but low, you're losing voltage somewhere.  I would suspect dead capacitors or a bad connection on the wiring harness.  Check the speakers, too, they could just be torn or blown.
lebanull
« Reply #2 on: September 15, 2005, 12:21:58 pm »
Thanks for the reply. I've checked speaker, tested out and harness is okay.
« Reply #3 on: September 15, 2005, 12:29:47 pm »
How?
Another potential cause is a bad volume potentiometer.  If that is cracked, you're only going to get a small portion of the voltage flow through it.
lebanull
« Reply #4 on: September 15, 2005, 12:47:03 pm »
I will rebuild the amp and go from there. Do you know of a replacement monitor that would work?
Thanks!!!!
« Reply #5 on: September 15, 2005, 01:06:44 pm »
I am not that familiar with the monitors that Nintendo used.
If you are working on the sound amp, there is no need to discharge the monitor.  They are separate.
Why do you want to replace the monitor?  At this point, you're saying the sound amp has a problem, the cab itself is not worth salvaging, and the monitor needs to be replaced.
At this point, you just get a different cab and swap the game PCBs into it since nearly everything worth having on the original isn't worth saving, from the info you are giving.
lebanull
« Reply #6 on: September 15, 2005, 04:23:15 pm »
Replaceing the monitor was just a thought.
« Reply #7 on: September 15, 2005, 04:26:19 pm »
Ah.  If the monitor works, may as well keep it.  Nearly all monitor issues can be repaired without a huge amount of trouble once you have learned enough to do so.  These monitors are simpler than they appear to be.
lebanull
« Reply #8 on: September 15, 2005, 11:32:52 pm »
...so they seem to be.
Here are my before shots. With two kids and a job with many hours, I hope this doesn't take too long :)
Notice the dust on the monitor? 23yrs of arcade dust!!
What do you guys think about the burn in? Have you seen worse?
« Last Edit: September 15, 2005, 11:36:50 pm by lebanull »
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
« Reply #9 on: September 16, 2005, 07:10:37 am »
Sounds right and Bob Roberts used to have Nintendo Audio Board Cap Kits ... I had been intending to order one for my SMB.
Cheers
Working: Not Enough
Projects: Too Many
Progress: None
CheffoJeffo
« Reply #10 on: September 16, 2005, 07:13:53 am »
Quarter Arcade has rebuilt 19" monitors for the early Nintendo cabs, including the Audio Board. I had looked at picking one up for my SMB project, but am going to trying capping the current monitor instead.
http://www.quarterarcade.com/Game.aspx/4864
Cheers.
Working: Not Enough
Projects: Too Many
Progress: None
CheffoJeffo
« Reply #11 on: September 16, 2005, 07:20:50 am »
Is that 3/4" particle board ? Hmmm.
Cheers.
Working: Not Enough
Projects: Too Many
Progress: None
lebanull
« Reply #12 on: September 16, 2005, 08:26:11 am »
thanks for the input
Cheers
« Reply #13 on: September 16, 2005, 08:58:23 am »
Unless there is damage you're not showing, that cab is not only savable but in pretty good shape.  Take a look through some other restoration projects around here to see the lengths to which people go to save cabs.  Yours looks like it needs a little filler here and there, a fresh coat of paint and some T molding.  That's an easy restoration.
The inside of the cab is also remarkably clean.  No insects, no rodent nests, no mold or water damage.  I'd say you got a cab in pretty good shape, not a crappy one.
I definitely feel what you're saying about kids and a job, I am in the same boat.  Sometimes the projects just don't seem to move along for weeks at a time.
Wade
  • Last login:Yesterday at 03:31:11 pm
  • 80's Child
    • Wade's Gameroom
« Reply #14 on: September 16, 2005, 10:00:13 am »
Yeah, from the photos, that game doesn't look bad at all.  The monitor burn looks minor, if it isn't noticable when the game is running and the picture is good, I would keep it and not replace it.  I have a couple of games with much worse burn.
Wade
« Reply #15 on: September 16, 2005, 10:14:31 am »
My Tank II has such bad burn my kids like to play it tracing their fingers on the screen while the game is off.
lebanull
« Reply #16 on: September 16, 2005, 12:26:07 pm »
Okay, My question about saving this cabinet...How would I fix the corners that have no place for t-molding to rest in? I'm not that handy at wood working, any thoughts? as you can see at the bottom, it's missing a complete pc of wood, that I would need to cut.
Any Ideas as to what kind of wood filler works best on these? Maybe I will try to save this guy? ANd how about a good primer? The paint I would have no problems matching.
Thanks so much!
« Reply #17 on: September 16, 2005, 12:27:42 pm »
I don't see any places where you have to cut new wood.  The best way to repair that would be Bondo.
I usually use Kilz as a primer, that stuff will prime anything.
lebanull
« Reply #18 on: September 16, 2005, 12:31:12 pm »
sorry about that, it's the very bottom front(black pc) that's missing. You cant see it.
lebanull
« Reply #19 on: September 16, 2005, 12:35:35 pm »
Heres a bad corner:
« Reply #20 on: September 16, 2005, 12:36:19 pm »
Very simple Bondo fix.  Look at any number of other restoration projects here for examples.
lebanull
« Reply #21 on: September 16, 2005, 12:37:52 pm »
thanks Chad! You might of saved me 50.00. The pints are on me :) CAn you route the bondo so that tmold will fit?
« Reply #22 on: September 16, 2005, 12:43:54 pm »
Once it has hardened you can do pretty much what you want with it.
Sinner
  • Last login:September 17, 2024, 11:27:45 am
  • Half the lies they tell about me, aren't true...
    • Geek My Gadget
« Reply #23 on: September 16, 2005, 01:10:25 pm »
I've used wood filler on my damaged corners.  In your opinion, will it last?  Should I sand it out and use Bondo??
« Reply #24 on: September 16, 2005, 01:11:52 pm »
I'm not enough of an expert to answer that, but I can tell you that Bondo is made for the long term.  The long, long term.
Sinner
    • Geek My Gadget
« Reply #25 on: September 16, 2005, 01:16:32 pm »
lebanull
« Reply #26 on: September 19, 2005, 11:35:52 am »
Okay. So before I enter the world of bondo, here are my biggest problems:
What would be my best solution here? Remove all that has been cracked before I bondo?
#2
This is the right side bottom, biggest piece that
Re: My First Arcade Restore: Project Popeye
« Reply #27 on: September 19, 2005, 11:38:14 am »
Once the Bondo has dried, you're going to have to route a new groove for T Molding, so don't worry too much about that.  What you're going to do here is basically recreate the missing parts with  Bondo and then route a new groove in there for T molding.
lebanull
« Reply #28 on: September 19, 2005, 11:40:06 am »
Thanks for the *quick* reply. Tips for reshaping these pcs?
thanks,
« Reply #29 on: September 19, 2005, 11:42:13 am »
I don't have much hands on Bondo experience, sorry.   :-\
lebanull
« Reply #30 on: September 19, 2005, 11:49:57 am »
I will hunt for some tips   ;D
lebanull
« Reply #31 on: September 19, 2005, 05:34:14 pm »
UPDATE:
I had the day off today. So, I decided to restore the controller. All original except, new buttons, t-mold, bolts,instruction card and joystick guard. I think it cleaned up rather nicely.
more to come
« Last Edit: September 26, 2005, 03:39:11 pm by lebanull »
Wade
  • 80's Child
    • Wade's Gameroom
« Reply #32 on: September 21, 2005, 08:44:34 am »
I'd say that's about a 5.  But I wouldn't bother changing it unless the burn is noticable when the game is on and the tinted plexi shield is installed.  I have some games with far worse burn, but it isn't noticable when the game is running.
Wade
« Reply #33 on: September 21, 2005, 09:17:02 am »
It would be a bigger issue if it was in a cab other than Popeye.
Wade
  • 80's Child
    • Wade's Gameroom
« Reply #34 on: September 22, 2005, 04:36:34 pm »
Yeah, that too. I don't mind burn nearly as much if it is for the current game.  It just shows that it is original. :)
Wade
TOK
  • The Game Always Wins
« Reply #35 on: September 22, 2005, 09:10:56 pm »
My Bally cab had really beat up corners and edges. I used rigid carboard to give me a roughly square line, then sanded. You can't see it after paint.
lebanull
« Reply #36 on: September 22, 2005, 09:18:43 pm »
Tok - thanks for the tip! I'm currently tossing aroung the idea of making this Popeye into a DK,,,,, :o
TOK
« Reply #37 on: September 23, 2005, 10:34:09 am »
I played Popeye, but never cared for it too much for it because I never felt comfortable hitting the perfect diagonals required for the stairs.
The cab is the same, DK parts are pretty cheap and plentiful, so you can convert it back and forth without doing any permanent physical changes to the cab. Not bad!
« Reply #38 on: September 23, 2005, 11:13:48 am »
Well, except the side and cp art.
TOK
« Reply #39 on: September 23, 2005, 02:28:30 pm »
I didn't consider the side art, but when I mentioned the DK parts, I meant he could just buy another panel. I guess since you're stuck with the Popeye side art anyway playing DK on a Popeye control panel wouldn't be so bad.
Better than playing Popeye, at least!  ;)
