Author Topic: What type of Glass?  (Read 1863 times)
chris2922
  • Last login:March 26, 2023, 01:09:41 pm
  • Silverline Jamma Cab
What type of Glass?
« on: September 13, 2005, 02:32:53 pm »
Im about to build an cocktail mame cab with a 17" PC monitor.
(Its not for me, and its on a budget).
I intend to use a large piece of glass to cover the top - give it a kind of coffee table look.  Underneath that will be a piece of mdf with a square cut out revealing the monitor.
Has anyone built something similar?
I intend to use smoked, strengthened glass but im interested in hearing other peoples advice.
Ken Layton
  • Guru
  • Technician
Re: What type of Glass?
« Reply #1 on: September 13, 2005, 06:06:23 pm »
Tempered glass is extremely sensitive to any taps on the edge. The glass will shatter and go everywhere.
« Reply #2 on: September 13, 2005, 07:19:55 pm »
I am waiting for the local glass shop to finish my tabletop right now.  I am using a standard Ms. Pac-man shaped top and there is going to be a piece of 1/8" grey smoked glass covering the monitor (sitting in the groove around the monitor cutout on top of the bezel and flush with the table top) and a piece of 1/8" tempered clear glass covering the entire top held in place with glass clips.  Everything total was $150 ($100 for the tempering process!).  It's a bit much but at this point it doesn't even matter anymore.  As soon as it comes in I am going to assemble it and I will post some pictures on my stupid blog www.knightsofthearcadetable.blogspot.com.
jedi27
  • Last login:June 11, 2007, 11:07:28 am
  • Models make people feel good about themselves.....
« Reply #3 on: September 13, 2005, 09:03:43 pm »
Definately go for the tempered stuff..  about 10 times stronger than "normal" glass...
I almost went the smoked route - wished I would have... yes - beware of the bronze vs the grey smoked stuff..
I haven't heard anything about the tendency to chip...
Bones
  • [Moderator]
« Reply #4 on: September 13, 2005, 09:14:22 pm »
Mine was described as "laminated glass" which is 2 pieces 3mm glass fused together with a grey tinted film between the two pieces.
It was explained to me that if it does break you won't get shards of glass fly everywhere, it resembles a car windscreen break where the glass is safely retained in place.
« Reply #5 on: September 13, 2005, 09:15:20 pm »
$100 for tempering?
OUCH.
Highest I got quoted for glass, cut, radius corners AND tempering on a Ms.Pac cocktail was about $60. cheapest was $45
Yup.
