February 05, 2026, 04:26:30 pm
Lighten up.....
Quote from: Dartful Dodger on September 22, 2005, 04:31:21 pmLighten up..... Racist!
If my example is not based on race, but on hair, then yours is based on height, not on race.
Barber booster seats are usually higher on one side than the other.
I wonder how many people in this country understand the difference between racism and racial discrimination.Racism is natural and part of recognizing the difference between yourself and another individual.
is that like if you have a flat tyre all you have to do is turn it around so the flat bit is at the top? i guess im going to have to spell it out. it wasn't a booster seat, it was just a thin cushion thingo like you might use in a car. It doesn't matter which side you turn it, it will still be the same height. When the previous customer left (who was about the same height as me and not a small boy), the barber looked at me, screwed up his nose and made a deal out of turning the cushion over...
I am not racist.
Quote from: danny_galaga on September 23, 2005, 10:15:42 pmis that like if you have a flat tyre all you have to do is turn it around so the flat bit is at the top? i guess im going to have to spell it out. it wasn't a booster seat, it was just a thin cushion thingo like you might use in a car. It doesn't matter which side you turn it, it will still be the same height. When the previous customer left (who was about the same height as me and not a small boy), the barber looked at me, screwed up his nose and made a deal out of turning the cushion over...Just give up your dumb analogy.
