Author Topic: can mamewah run vertically>? quick answer iff possible  (Read 2175 times)
GMZombie
  • Last login:March 22, 2022, 10:11:23 am
  • I am a living Legend who fixes stuff... mostly
« on: September 10, 2005, 05:04:29 pm »
just as the post says can it run vertically as im puttin it into a vertical cab and would love to use it...i heard of vertiwah but cant seem to find it anymore...anyways thanx for the answrs
sc1103
  • Last login:December 11, 2020, 08:37:35 pm
youki
  • Atomic Front End Creator
    • Atomic Front End
Re: can mamewah run vertically>? quick answer iff possible
« Reply #2 on: September 11, 2005, 05:25:47 am »
AtomicFe can.
http:\\www.atomicfe.com  :)
swindus
  • Last login:July 28, 2021, 05:52:50 am
    • MaLa - M.A.M.E. Launcher
« Reply #3 on: September 11, 2005, 05:56:20 am »
AtomicFe can.
Yes, but you have to rotate your windows desktop. Or is it possibly to rotate AtomicFE by 90 or 270 degrees on a 800 x 600 desktop for example without rotating the windows desktop?
If you rotate your desktop I would say every windows application can run 'vertically'.  ;)
« Last Edit: September 11, 2005, 06:06:59 am by swindus »
youki
    • Atomic Front End
« Reply #4 on: September 11, 2005, 02:19:01 pm »
Swindus, stop talking without knowing what about your talk please.
I read your other post  in German on german forums talking about Atomic and Animated layouts   You never tried it , and you have absoltly no idea of what it can do or not and how i did that.
So , i don't comment your FE , so don't comment mine.
You don't have rotate windows desktop to rotate Atomic.  Atomic can have specifics vertical layouts and as well use horizontal in vertical mode.    Atomic rotate the layout for you.
swindus
« Reply #5 on: September 11, 2005, 02:35:45 pm »
Hey, it was just a question.  :P
Thanks for explaining ...
Never talked bad about your frontend! Maybe you misunderstood some things on the german boards because it is written in german. And yes, I tried your frontend. So calm down ...
GMZombie
« Reply #6 on: September 11, 2005, 06:03:54 pm »
hey thanx to all that have helped...ive decided to go with atomicFE cause it looks cool and also because vertiwah wouldnt except the resolution i was at for some weird reason...there are alot of cool things with this FE and i like it...thanx again
Minwah
    • MAMEWAH
« Reply #7 on: September 11, 2005, 07:18:19 pm »
I realise the point is probably moot now but just to answer the question...swindus' answer was correct with respect to Mamewah, not AtomicFE, ie Mamewah can be used vertically but only if your Windows desktop is rotated.
This will probably change, but not for a long time...
