Author Topic: UAII monitor Depth..does it matter?  (Read 953 times)
Ldsfunaz
  • Last login:March 07, 2006, 06:32:01 pm
  • "Super NinCadeO, Sega Genesis!!"
« on: September 09, 2005, 07:11:36 pm »
Im at the stage where i am finally about to build..probably start on monday. my main question is for all you UAII experts is that in the plans is says the monitor depth is only 20 7/16".  I havent really found a TV online that is near that small.
Im not as worried about the width because i can find tvs that can fit.
Does it matter if the tv is deeper than the space allowed, would the tv just stick out the back off the shelf a little bit?
on a side note, whats the deal with the supplemental sheet from the project arcade CD?  theres no instructions for that, or any explanation for that matter...
thanks alot
digitalpackrat
  • Last login:April 20, 2013, 07:05:52 pm
  • Cabinet currently in progress
Re: UAII monitor Depth..does it matter?
« Reply #1 on: September 09, 2005, 07:41:41 pm »
I'm loosly basing my cab off of UAII design.  My 27" TV is only 19" deep which gives me about 2-3" to play with if i decide to go with a different TV but most of the new flat TVs are ~20" deep.  Here's my work in progress
http://forum.arcadecontrols.com/index.php?topic=42121.0
