Author Topic: What groove depth is standard for t-molding?  (Read 1558 times)
eggedd2k
  • Last login:February 14, 2006, 09:38:56 am
« on: September 07, 2005, 03:49:41 pm »
the guy who's gonna cut my cabinet bits out is gonna need to know what depth groove i need routing out for t-molding.
is there a standard depth?
Re: What groove depth is standard for t-molding?
« Reply #1 on: September 07, 2005, 04:46:45 pm »
It's whatever the slot cutter radius is... it doesn't really matter.
Skadar
  • Last login:August 07, 2017, 02:20:01 pm
  • I love my new Corsair keyboard: RRRrrrrrr!!!!
    • Ooine.com
« Reply #2 on: September 07, 2005, 04:57:58 pm »
The depth of the groove is beyond the means of most of us to alter.
This is because most of us don't have a selection of router bits at hand and only shell out the money for a single tri-wing slot cutter, arbor, and bearing.  The depth of the slot can be varied by using different sized bearings on your router arbor, but most of us only want to buy 1 bearing as necessary.
The bearing that came with my slot cutting arbor creates a 1/2 inch depth slot... which is more than is necessary.
Lilwolf
« Reply #3 on: September 07, 2005, 06:18:29 pm »
SPARE WOOD
take a piece of scrap and test your tmolding out before you start on your cab.
(not a question you would ask if you tried on spare wood...)
jedi27
  • Last login:June 11, 2007, 11:07:28 am
  • Models make people feel good about themselves.....
« Reply #4 on: September 13, 2005, 09:14:23 pm »
My slot cutter cuts around 5/8" deep - the slot really only needs to be about 1/4" in depth...
t-molding.com has the full measurements posted -
