Author Topic: OS taskbar help  (Read 1436 times)
neil99a
  • Last login:July 15, 2006, 09:45:28 am
OS taskbar help
« on: September 06, 2005, 11:50:19 pm »
Somebody PLEASE help   :'(
I am running XP and have used the tweakui utility to fix up the desktop/settings.  I minimize the taskbar and get a nice clean desktop but everytime I reboot the taskbar is back and the start up menu opens.  How do I fix this?  Bill Gates.... you suck!
N
loadman
    • MaLa
Re: OS taskbar help
« Reply #1 on: September 07, 2005, 12:17:31 am »
Don't have an answer for that question.
But I run XP(Sp2) and the Front end 'Mame Launcher (MaLa)'.
It hides the taskbar as it launches.
http://mala.arcadezentrum.com/features.htm
Minwah
    • MAMEWAH
Re: OS taskbar help
« Reply #2 on: September 07, 2005, 05:55:35 am »
It may help if you turn off themes and use the 'classic' start menu, I'm not sure tho.
Hoopz
  • Intellivision Rocks!
Re: OS taskbar help
« Reply #3 on: September 07, 2005, 09:59:29 am »
Right click on the Start button, select properties, select the "taskbar" tab.
Make sure the box for "Keep the taskbar on top of other windows" is NOT checked.
ahmer
  • Last login:March 16, 2014, 02:40:21 pm
  • Do as you like.
    • IC Markets Rebates and Discount
Re: OS taskbar help
« Reply #4 on: September 07, 2005, 04:41:46 pm »
You should make your frontend as XP shell to completly get rid of windows environments + fast acces,as we always do.
