Author Topic: Dual Monitor Question  (Read 2309 times)
missioncontrol
  • MC-Retro says Wot!
  • Trade Count: (+13)
« on: September 05, 2005, 10:35:10 am »
O.k. I've got a NVIDIA GeForce4 MX 440 video card that can supposibly have two monitors hooked up to it. I was hoping that once I plugged in the second monitor windows would detect it and help in setting it up, but no luck.
I uninstalled the video drivers and the re-installed them hoping than it would detect two monitors and help me set it up, no luck again.
my qusetion is anybody know how to set up the use of two monitors with this card?
I am running windows 2K pro.
thanks........
M3talhead
  • Last login:October 09, 2020, 07:35:12 pm
  • Dont let Donkey Kong use your toilet.......
Re: Dual Monitor Question
« Reply #1 on: September 05, 2005, 11:10:04 am »
I have the 440 Go in my laptop (same chipset).
Make sure you have the video out plugged into whatever your have as your 2nd display. Go to Display Properties > Settings > Advanced > nView.
Your 2nd monitor should show up there. Make sure that the "Clone" option is checked. Hit ok and the 2nd display should mirror you desktop.
Signature tags are dumb.
missioncontrol
« Reply #2 on: September 05, 2005, 11:25:10 am »
wow cool it works.......
thanks M3talhead.
M3talhead
« Reply #3 on: September 05, 2005, 11:45:20 am »
Wohoo!!
Post # 666!!!
Time to throw on some 'Maiden!
missioncontrol
« Reply #4 on: September 05, 2005, 11:51:11 am »
this is really cool boobs on one screen BYOAC in the other....
I may never leave the house again...........
Harry Potter
  • Smite-bait
  • Last login:May 27, 2024, 03:33:28 am
  • Sober until banned. Can post but still can't read.
« Reply #5 on: September 05, 2005, 01:20:55 pm »
just got mine today as well.
But I put boobs on both screens.  ;D
Now in a tasty new flavour.
shmokes
  • Don't tread on me.
    • Jake Moses
« Reply #6 on: September 05, 2005, 02:19:35 pm »
Are you sure you want to select "clone"?  I'm not using an Nvidia card, but I understand that cloning will put the same image on both monitors and "extend" will allow you to use both monitors as though they were a single larger monitor.
Best Kid iPad Apps
missioncontrol
« Reply #7 on: September 05, 2005, 02:27:45 pm »
I used horizontal span
I'm still playing with trying to tweak it just right, but I'd like to set it up the same way it's used in my web design class where the mail screen has the task bar and the other screen is just blue until you drag the progam you are running over there.
any suggestions on how to keep the toolbar to just one screen like that?
« Last Edit: September 05, 2005, 02:31:22 pm by missioncontrol »
pointdablame
« Reply #8 on: September 05, 2005, 10:01:15 pm »
download Ultramon.  You can add/remove a task bar and do a ton of other stuff as well.
If you're running dual monitors, you NEED Ultramon IMHO.
first off your and idiot
missioncontrol
« Reply #9 on: September 06, 2005, 11:56:48 am »
thanks I'll try it do you have a trusted link or should I just google it?
Stingray
« Reply #10 on: September 06, 2005, 12:07:34 pm »
I've been running dual monitors on my Mac at home for years. It's very easy to get used to it, and very hard to go to a machine with only one monitor after you do get used to it. I really wish I had that setup at work.
-S
missioncontrol
« Reply #11 on: September 06, 2005, 12:10:07 pm »
with dial up this duel monitor is the only way to go while one page loads on one monitor read the other.......
I've had this video card in my p.c. for a year now and I'm just now setting it up....
boy have I missed out.......
Sephroth57
  • Poo Monkey
  • Last login:June 07, 2020, 11:17:00 am
    • Check it out!!!
« Reply #12 on: September 06, 2005, 12:16:44 pm »
i have no room on my desk for another monitor , my 21 inch CRT takes up all the room. but then again its so large i dont need 2
"Owens is the ringleader in the ass hat circus"  D K
Stingray
« Reply #13 on: September 06, 2005, 12:30:45 pm »
One of mine is a 21 inch, the other a 17. If I had room, I'd add a third. You can never have too much screen real estate. :)
-S
missioncontrol
« Reply #14 on: September 06, 2005, 12:35:41 pm »
I've just got 2  17"
M3talhead
« Reply #15 on: September 06, 2005, 03:47:40 pm »
I've just got 2  17"
Man, I thought 8" was impressive.........
Stingray
« Reply #16 on: September 06, 2005, 03:50:22 pm »
I've just got 2  17"
Gozur will sell you one that's only 8 inches and you can touch it.
-S
