Author Topic: What size monitor was in a Defender cab?  (Read 5881 times)
eggedd2k
  • Last login:February 14, 2006, 09:38:56 am
« on: September 04, 2005, 03:01:45 pm »
i'm making a defender cab from scratch (using the plans from the jakobud site). i was just wondering what size monitor they used to have in them? mine's gonna have to be a computer monitor.
Grasshopper
Re: What size monitor was in a Defender cab?
« Reply #1 on: September 04, 2005, 03:16:44 pm »
19" I believe.
toolaa
  • Last login:April 04, 2024, 02:03:09 pm
  • Work In Progress...
    • Moon Patrol Project
« Reply #2 on: September 04, 2005, 03:48:56 pm »
I've got a 19" low res from Moon Patrol.  It's the same monitor in Defender.  It works but has some burn in.  Needs a cap kit.  If you live near Baltimore Md and can pick it up.  It's yours...  I can't mess with shipping this however.  I should have tossed it out weeks ago, but I just can't seem to let it go to waste.
Super Sprint - In Progress ($150)
Moon Patrol MAME - Completed ($670)
Tic-Tac-Strike Puck Bowler - Restored ($1200)
First Time Visitors Say "Holy Cow!"
. . . . . .Priceless
eggedd2k
« Reply #3 on: September 04, 2005, 03:55:27 pm »
i'm in the uk m8 - thanks for the offer though.
i'm making the defender cab from scratch so i'll probably stick at 19" computer in it.
MaximRecoil
« Reply #4 on: September 04, 2005, 04:02:49 pm »
If you are going to use a PC monitor, get a 20" if you can, since that will be the equivalent of a 19" TV or arcade monitor. A 19" PC monitor is only 18" viewable, while a 19" TV or arcade monitor is 19" viewable.
eggedd2k
« Reply #5 on: September 04, 2005, 04:04:56 pm »
thanks for the advice - do you think a 20 inch computer monitor will fit in a defender cab?
MaximRecoil
« Reply #6 on: September 04, 2005, 04:10:38 pm »
I don't know; depends on the monitor I guess. It would definitely fit if you removed all of the plastic housing which is the way arcade monitors are mounted in there. It may fit without removing the plastic housing, since I think I've seen 25" monitors stuffed into Defender-size cabinets before. Just do some measurements.
toolaa
« Reply #7 on: September 04, 2005, 04:40:31 pm »
I have a 24" Sony TV in my Moon Patrol Cab, so I am almost sure the 20" TV or Monitor will fit.
Here is a link to some details.
http://home.comcast.net/~toolaa/moon_patrol/Moon_Patrol_Project.mht
tristan
  • Last login:October 07, 2022, 05:37:32 pm
  • I have no idea what's going on
    • Nothing
« Reply #8 on: September 04, 2005, 04:52:39 pm »
Mine had a Wells Gardner 4900 19" in it. There is definately some clearance on each side.
eggedd2k
« Reply #9 on: September 04, 2005, 04:55:46 pm »
thanks for the advice - i'll have to wait till the cab's built then experiment with some monitors from work.
Ken Layton
  • Guru
  • Technician
« Reply #10 on: September 04, 2005, 05:57:46 pm »
Defender used a 19" horizontal (a.k.a. "shelf") mount color raster monitor. All the ones I have worked on were originally shipped with either an Electrohome G07 or Wells-Gardner 19k4600 series monitor inside.
TOK
  • The Game Always Wins
« Reply #11 on: September 04, 2005, 06:34:20 pm »
Cool project. Since you're using a PC monitor, I'm guessing you're using MAME and not a dedciated PC. Have you considered doing a multi-Wiliams?
Thats probably the one cabinet with a very limited number of games that I'd be completely happy with.
pmc
  • Last login:December 20, 2023, 07:43:02 am
    • website
« Reply #12 on: September 05, 2005, 09:13:45 am »
I have a 21" monitor in my scratch-built defender cabinet and there's still plenty of room for a bigger one. It's an older monitor (i.e., large), so it wants to protrude through the back a bit. But there is tons of space around the top, bottom, and sides. Mine is on a swivel-stand and is merely sitting on a shelf.
Please post pics when you are done.
-pmc
eggedd2k
« Reply #13 on: September 05, 2005, 09:46:09 am »
i shall post some WIP plus completion pics.
when you say it protrudes from the back - do you mean you don't have a back on your cab? i deffinitely want one on mine
pmc
    • website
« Reply #14 on: September 05, 2005, 10:54:53 am »
I have a rear door panel, but it's not actually mounted on the cabinet. The monitor itself extends back to that panel, and then the wiring protrudes a little beyond that (just an inch or so). I always figured that I'd a) smoosh the wiring against that back door, b) cut a small window to allow them to stick out, or c) re-wire with angled connectors or something like that. In the meantime, I've been happy with d) no rear door for now.
If you have a modern monitor, I'll bet that you have no trouble making it fit.  The old ones, and particularly the big ones, were often very deep.
I look forward to seeing your WIP.
-pmc
quarterback
« Reply #15 on: September 05, 2005, 11:03:33 pm »
-- Chad Tower
