Author Topic: Killer Instinct sound issues?  (Read 5072 times)
lettuce
  • Make It So!
« on: September 02, 2005, 05:02:22 pm »
Is there a way to stop the sound skipping that sometimes accures in killer instinct on mame?
elvis
  • penguin poker
    • StickFreaks
Re: Killer Instinct sound issues?
« Reply #1 on: September 03, 2005, 12:56:30 am »
Audio skipping in MAME occurs for one of two reasons:
1) Your audio buffer/delay isn't high enough.  This would cause sound skipping in ALL games.  or
2) Your computer isn't fast enough.  This would cause sound skipping in newer titles.
If your problem is (1) then the solution is documented in here:
http://www.mame.net/readmewin.html
(I'll let you read the docs for yourself and find the answer  - hint: search the document for "audio". :) ).
If your problem is (2), then it's time to upgrade your CPU, or use a different emulator.
« Last Edit: September 03, 2005, 03:16:37 am by elvis »
stevodevo
  • Last login:March 07, 2022, 11:27:18 am
« Reply #2 on: September 06, 2005, 02:34:56 pm »
I'd almost say if you can run KI in mame then your computer must be fairly decent.  I couldn't run it on my 1.6Ghz 640meg ram pc without slowdown.  I'm using another emu to run it called u64Emu - google it.  I'm running it in my cab via MameWah.  Works great.
lettuce
  • Make It So!
« Reply #3 on: September 06, 2005, 05:40:25 pm »
its an athlon 2400 cpu with 512 ram, so its on the top end for mame stuff
elvis
  • penguin poker
    • StickFreaks
« Reply #4 on: September 06, 2005, 05:54:27 pm »
Can you benchmark KI and post the results here?
motorfish
  • Last login:September 30, 2009, 03:35:08 am
« Reply #5 on: September 06, 2005, 09:12:06 pm »
I'm running an Athlon 3200 with a gig of RAM, and KI2 still slows down for me. I can almost run it at full speed, but not quite....
KI1, no problem.
- Dan
Have you paid your dues Jack?......Yessir, the check is in the mail!
motorfish
« Reply #6 on: September 08, 2005, 08:59:29 pm »
Are you using an on-board sound card? If so, that might account for your problems, as on-board sound steals cycles from your processing time.
- Dan
elvis
  • penguin poker
    • StickFreaks
« Reply #7 on: September 08, 2005, 09:21:36 pm »
- Dan
Careful when making broad sweeping statements like that.  Modern AC'97 sound on Intel, Via and Nvidia boards do not "steal cycles" at a higher rate than any high-end plugin card you can consider.
Perhaps back 5 years ago when onboard sound first appeared it was the case, but things have changed a great deal since then.
motorfish
« Reply #8 on: September 09, 2005, 08:55:07 pm »
So noted.
motorfish
« Reply #9 on: September 09, 2005, 08:56:23 pm »
So I'm guessing that my compurter just isn't fast enough to run KI2 at full speed. I was sure an Athlon64 3200 would've chewed this game up, but no dice.
- Dan
elvis
  • penguin poker
    • StickFreaks
« Reply #10 on: September 10, 2005, 03:49:14 am »
Benchmarks from MAME32's author John V:
http://www.classicgaming.com/mame32qa/bench.htm
kinst2 running on MAME 0.94u5:
Athlon64 3200+ at 93 FPS
Athlon64 3700+ at 111 FPS
http://www.classicgaming.com/mame32qa/old_bench.htm
kinst2 running on MAME 0.83u3:
Athlon 64 3200+ at 94 FPS
Athlon 3000+ Barton 333FSB at 76 FPS
P4 3Ghz HT 533FSB at 109 FPS
P4 3.20Ghz HT 800FSB at 117 FPS
Looking at those benchmarks, I would interpolate that Killer Instinct 1 and 2 (the use identical hardware) runs best on Intel P4 architecture, and at roughly 2.8GHz minimum for half-decent play.  60FPS minimum is what you want, so a 60FPS "average" (which is what the MAME benchmarks show) isn't enough.  You need a bit more than that to cover your highs and lows.
No, it's not "top end for MAME stuff".  From the benchmarks above, it would be borderline acceptable for KI, and result in occasional sound skipping as the system tries to frameskip.  The same thing will happen when you try newer 3D games like Tekken, etc.
As mentioned, either upgrade your hardware, or change emulators.  Any of the Nintendo Ultra64 HLE-style emulators will perform well, and give near arcade perfect emulation.  And if "near" isn't good enough, then bite the bullet and spend some money on an upgrade.
Or conversely, crack open the MAME source and start optimizing.  That's the beauty of having the source-code available to you. :)
« Last Edit: September 10, 2005, 05:59:15 am by elvis »
motorfish
« Reply #11 on: September 10, 2005, 05:46:22 pm »
My emulator may indeed be where I'm hitting my block. I'm using MAME32 v. 98 or .99
I'll attempt to roll back to an earlier version.
- Dan
motorfish
« Reply #12 on: September 11, 2005, 05:23:05 pm »
Nope, not working out. KI2 on my machine dips down to 48 fps once in-game. Weird...
I'm running:
Windows XP Pro Sp1
MB - K8N Neo 4
Processor - Athlon 64 3200+
1 gig ddr ram
What the hell is slowing me down?
« Last Edit: September 11, 2005, 05:27:00 pm by motorfish »
