Author Topic: Two joysticks side-by-side  (Read 2917 times)
Mario
  • Last login:March 29, 2021, 08:55:12 pm
  • Mmmmm.....arcades!
    • Mario's Arcade Page
« on: August 31, 2005, 10:43:52 pm »
I want both an 8-way and a 4-way joystick on my CP. I was thinking of putting the two joysticks right next to each other, with a small amount of space between them. It seems like it might be comfortable and they won't interfere with each other. And the hand placement during play is almost exactly the same for each joystick.
Has anyone done this? Is it a good or bad idea?
Mario
Timoe
  • Team-Oh-tAy-Oh
    • Rattlin' Trash
Re: Two joysticks side-by-side
« Reply #1 on: August 31, 2005, 11:32:59 pm »
Sounds like it should work.  It seems so simple that there must be something wrong with it.  Like, why haven't we seen it before?
Its probably an aesthetic thing.
Apollo
    • Eight Bells
« Reply #2 on: September 01, 2005, 12:44:46 am »
Get yourself a T-stick plus.
http://www.ultimarc.com/controls.html
Xiaou2
  • Last login:Yesterday at 01:42:01 pm
  • NOM NOM NOM
« Reply #3 on: September 01, 2005, 06:48:33 am »
 You could also put them side by side - but vertically.
  •     ooo
  •   ooo
nostrebor
  • SHOCKING!!
« Reply #4 on: September 01, 2005, 07:40:50 am »
I had to have WICO leafswitch sticks, so I did an offset. The 8-way is far left, 4-way is upper middle. Third stick is another 8-way for Robotron. It works great!
SaiNRuB
  • Last login:November 26, 2024, 07:30:53 pm
  • Pluck your magic twanger, Froggy!
« Reply #5 on: September 01, 2005, 08:33:41 am »
Thats really slick there NOS.
Hey how did you fabricate the front plexiglass cubby hole for the admin buttons. Thats really some nice handywork.
Mario
« Reply #6 on: September 01, 2005, 06:34:27 pm »
I already have the 2 joysticks. Also, I tried  the T-stick and I wasn't too thrilled with the feel in 4-way mode.
Mario
whatsyours
  • Last login:September 26, 2005, 07:15:50 pm
« Reply #7 on: September 15, 2005, 06:27:42 pm »
KungFuJoe
  • Last login:February 05, 2006, 05:10:10 am
« Reply #8 on: September 15, 2005, 07:00:59 pm »
I did the side by side thing...works fine and what's cool is that you save on buttons because, say the 4 way is between two 8 ways (with accompanying standard 6 button layouts).  For right handed players, they can use one set of buttons, and left handed players can use another.  So basically, you don't need any dedicated buttons for the 4 way.,
paigeoliver
  • Awesome face!
« Reply #9 on: September 15, 2005, 08:20:24 pm »
If you use a Happ Ms. Pac reuion stick (mounted left side of the pair) and a full height wico or Happ stick (right side of pair), then you can literally mount them with the bases touching, and they won't even come close to getting in the way of each other.
You can't do it the other way around though, the reunion stick must be left side of the pair, unless you are one of those "joystick to the right of the buttons" freaks, in which case you have to reverse it.  ;D
nostrebor
  • SHOCKING!!
« Reply #10 on: September 15, 2005, 08:34:37 pm »
Wow, just noticed your question here. Sorry.
The recessed slot was cut all the way through the MDF with a 2 1/4" forstner bit at the ends, and I cut the middle out with a jigsaw. I smoothed everything down flat with a drum sander in my drill press. Then I radius the edges with a roundover bit in a router. The buttons are mounted to a 1/4" piece of plywood, which is mounted to the inside of the CP. The opening in the plexi was cut with a router with a 1/8" roundover bit, using the CP as the pattern. I then flame-polished the edge of the plexi opening to give it that crystal clear smooth look.
This cabinet is for my little girl, so the recessed buttons keep her from accidentally ending her game.
Oh, and thanks so much for the compliments.
Mario
« Reply #11 on: September 15, 2005, 11:47:53 pm »
Yeah, I like that, too. I wanted the buttons mounted in front, but I thought that people would accidentally hit them. This is a great way to mount the admin buttons. I think I'm going to do something like this with my cab.
Mario
SaiNRuB
« Reply #12 on: September 16, 2005, 08:17:27 am »
Very nice man, thanks for the detailed explanation.
Thats very innovative, kudos man!
Yeah Mario that would be real nice to include that for the admin buttons. :)
jcroach
  • Last login:March 01, 2012, 09:36:56 am
« Reply #13 on: September 16, 2005, 09:49:37 am »
Nice solution, nostrebor. I'd love to see more pictures of your cabinet.
nostrebor
  • SHOCKING!!
« Reply #14 on: September 17, 2005, 04:43:26 pm »
Thanks for the compliments guys!
More pics are here.
http://forum.arcadecontrols.com/index.php?topic=25002.0
