Author Topic: Advancemame .99 svgalib help  (Read 1110 times)
dabone
  • Last login:July 15, 2025, 08:32:17 pm
  • Time to work...
« on: August 31, 2005, 02:37:24 pm »
I'm trying to install .99 with vector linux with svgalib
and when I compile advancemame it only generatesthe following programs.
advmame
advm
advj
advs
advk
When I try to start advmame I get the error
No monitor clocks, etc...
Do I have to specify manually for linux?
I'm used to the dos version.
Thanks.
Later,
dabone
elvis
  • penguin poker
    • StickFreaks
Re: Advancemame .99 svgalib help
« Reply #1 on: September 01, 2005, 02:20:27 am »
You need to compile advcfg and advv.
Jump into the location where your advancemame source lives, and type:
make cfg
make v
In the same folder, executable versions of advcfg and advv will be created, and can be used to configure AdvanceMAME.  I don't know if it's  abug that these aren't built with the standard "make" command, or if the author intended it that way.  But it's been like that for 2 or 3 versions now.  Kinda silly.
whammoed
  • Last login:Yesterday at 09:03:23 am
  • Crack don't smoke itself
    • NiceMite
« Reply #2 on: September 01, 2005, 10:50:44 am »
make cfg
make v
elvis
  • penguin poker
    • StickFreaks
« Reply #3 on: September 01, 2005, 05:15:24 pm »
I did some clean installs of advmame 0.97 and 0.98 (virgin systems - brand new linux installs) and both showed the missing v/cfg problems.
Next time I'm building a system, I'll document the issue and post it to the author.
