Author Topic: Mounting a trackball on x-arcade  (Read 2126 times)
DannyH
  • Last login:August 17, 2009, 07:27:28 am
« on: August 30, 2005, 03:48:39 am »
Has anyone ever had a go at mounting a trackball on an x-arcade.
I am trying to think whether I should
1) cut a hole in my x-arcade and mount it internally
2) make a new control panel and mount it
3) make a new little box contraption for it and mount it in the space in between the monitor and the x-arcade or make and extenstion of the control panel and mount it infrom of that.
I think option 3 (the latter half of it) will be both the easiest and best result
Bones
  • [Moderator]
Re: Mounting a trackball on x-arcade
« Reply #1 on: August 30, 2005, 04:40:12 am »
Option 2 sounds like the most obvious solution. You then have the freedom to make it exactly how you want, rather than put it anywhere it might fit.
Option 3 sounds sounds like an exercise in frustration.
darthbane2k
  • Last login:September 30, 2009, 04:54:06 am
  • Built the cab, just need the time to play!
ROMbler
  • Last login:December 01, 2025, 10:51:49 pm
« Reply #3 on: August 30, 2005, 08:02:10 am »
I have an x-arcade 2 player and just got a trackball - my plan is to make a new CP with the x-arcade parts so I can add my trackball and eventually a spinner just the way I want it (Plus I get to keep the easy x-arcade setup in MAME ;))
Now all I need is the time to do it ???
Hey darthbane2k
« Last Edit: August 30, 2005, 08:07:47 am by ROMbler »
DannyH
« Reply #4 on: August 30, 2005, 06:23:31 pm »
Thats a good idea. My GF wasn't too thrilled about me getting an $100+ trackball so an explorer migh work, the only thing is the buttons, I wonder how I might be able to get around that.
flamethis
  • Last login:September 01, 2005, 08:19:21 pm
« Reply #5 on: August 30, 2005, 07:31:30 pm »
Cool, I came to this forum to ask this exact question and now I don't have to!
This place rocks!  Still not sure how to go about it but I love the amount of info here!
So many questions, so little patience....
