Author Topic: CPS3 Cd Drive Replacement!  (Read 4816 times)
jshum9999
  • Last login:September 20, 2007, 11:46:17 pm
« on: August 29, 2005, 03:37:47 pm »
Hey everyone,
I just got my CPS3 game in the mail today, and the cd drive was screwed up.
Does anyone know if I can replace the cd drive with any old cd drive?
Also is it just scsi or scsi wide?
I don't know the difference.
haha...scsi is so old, I dunno where I'm gonna find a cd drive.
agfisher
  • Last login:February 02, 2009, 03:13:16 pm
Re: CPS3 Cd Drive Replacement!
« Reply #1 on: August 29, 2005, 05:11:35 pm »
What does the connector look like on the back of the drive?
The standard SCSI connector was a 50 pin version of an IDE (standard Hard Drive) connector.
The Wide-SCSI connectors I used to use a shaped connector sort of late a parallel or serial cable only the pins are much thinner.
JB
  • Last login:October 21, 2005, 10:56:01 pm
« Reply #2 on: August 29, 2005, 06:32:17 pm »
Last I checked SCSI was still in common use, albeit not at the home user level.
dabone
  • Last login:July 15, 2025, 08:32:17 pm
  • Time to work...
« Reply #3 on: August 29, 2005, 07:08:02 pm »
Go here for ebay
http://tinyurl.com/83tnr
Grab a cheap one and try.
the cps3 faq says:
1.04: Can I change the CD-Rom?
A: Yes you can. On most CPS-3 it is a Panasonic 6x CD-Rom unit, model number CR-504. But another one makes no difference. Just buy a standard SCSI CD-Rom drive unit and set jumpers on the back properly. . Note: If you have to mount the game vertically be sure to to get a CD-Rom with clips to lock the CD inside the tray. Newer units dont have this feature.
CPS3 Faq:
http://www.guenstiger-essen.de/cps3faq/
Later,
dabone
jshum9999
« Reply #4 on: August 30, 2005, 12:13:29 pm »
Thanks for the help.
Now here's my second question.
How do I mount both the cps3 board and the cd drive in my machine at the same time?
I'm using a konami windy, and there's absolutely not enough room to mount both on the wood panel.
