Author Topic: Wells Gardner U3100 Yoke Flip - solved, thanks!  (Read 2627 times)
dweebs0r
  • Ascendo tuum!
« on: August 27, 2005, 02:25:33 pm »
Hello,
I have been reading all of the "yoke flipping" articles.
Including the Bob Roberts article, http://homearcade.org/BBBB/yoke.html
I am using a Wells Gardner U3100 SVGA monitor.  Here are my wires:
Do these look like I can pull them loose? or do I have to cut them?
I have already ruined a PC monitor with my inexperience and I am pretty reluctant to start cutting here.  Would I be better off buying a PCI video card that supports hardware flipping? (my onboard video doesnt rotate).
Suggestions?
Thx,
-Dweebs
« Last Edit: August 29, 2005, 06:58:30 am by dweebs0r »
whammoed
  • Last login:Yesterday at 09:05:01 am
  • Crack don't smoke itself
    • NiceMite
Re: Wells Gardner U3100 Yoke Flip - Help!
« Reply #1 on: August 27, 2005, 03:55:21 pm »
Its easy.  Just pull off that connector, cut it in two and flip both sides around.  Here is what it looks like after:
dweebs0r
  • Ascendo tuum!
« Reply #2 on: August 27, 2005, 10:27:30 pm »
How much force does it take to get that connector off?
I yanked on it pretty good.
Am I supposed to squeeze the sides or anything or just pull it straight off?
Thanks again for the help.
-Dweebs
  • Last login:February 22, 2026, 06:49:16 pm
« Reply #3 on: August 28, 2005, 07:19:42 am »
-Dweebs
I had the same problem.  I could not get that connector off.  So what I did was just cut and strip the wires, and switched them that way.  (Connect red to blue, blue to red, etc...)  This is also how I shocked myself.  So please please please make sure you are unplugged before doing this!    ;D
dabone
  • Last login:July 15, 2025, 08:32:17 pm
  • Time to work...
« Reply #4 on: August 28, 2005, 08:04:16 am »
The connector will come off.
DON'T YANK!
Rock the connector back and forth long ways.
If that doesn't work alone, take a small flathead screwdriver and use it to leverage the connector loose, after you get it a little loose then just pull it off the rest of the way.
And unplug your cab from the wall when doing this.
Later,
dabone
whammoed
    • NiceMite
« Reply #5 on: August 28, 2005, 12:07:02 pm »
dweebs0r
  • Ascendo tuum!
« Reply #6 on: August 28, 2005, 09:58:10 pm »
Well, I got the connector off with a pair of needle nosed pliars (really helped, I just couldn't pull it off by hand).
I then cut the plug in half and reversed the colors, just as I was told.
I plugged the monitor in (half expecting to see smoke and hear some frying noises.
None of that happpened so ... I plugged it in the computer and cranked it up and it worked perfectly!
Hooray!  Thanks to all of you for all of the help.  I have had such a string of failures that even just this little thing working out correctly makes me feel a little bit better.
Now, if I can get this monitor positioned correctly I will be well on the way to completing this project.
Thanks again!
-Dweebs
